Filling Conv. top motor
Old Sep 17, 2018 | 06:21 PM
2oldsguy's Avatar
What is the easiest way to fill the reservoir on the pump/motor and a 70 442?
Do you use brake fluid or auto trans fluid?
Thanks,
Joe
Old Sep 17, 2018 | 06:32 PM
Qwik71442's Avatar
Full-time Taxpayer
Old Sep 17, 2018 | 06:38 PM
Dave26's Avatar
The pump uses auto trans fluid. Some guys squirt the fluid into the pump. I like to take a piece of tubing, push it through a hole in an old rubber plug from the pump, pushed into the pump. The other end of the tubing in a container of trans fluid. Run the pump up and down, it will siphon the fluid into the system.
Old Sep 18, 2018 | 04:55 AM
2oldsguy's Avatar
Thanks for responses. The reason I asked what type of fluid is the shop manual said to use brake fluid.
how do I access the pump? How do I take the top well cover off?
Thanks,
Joe
Old Sep 18, 2018 | 05:35 AM
Dave26's Avatar
In the 1972 Oldsmobile service manual page 12-18 it states that Dexron ATF is used. Your pump is located in the trunk, attached to the rear seat back, you should be able to lift the top well cover and see it.
Old Sep 18, 2018 | 07:08 AM
Gary's 2 442-S's Avatar
Gary
Originally Posted by Qwik71442
That is a great tool to use. Made it easy for me to fill my pump.
Bitburger
Jun 20, 2019 08:20 AM
Bfg
Sep 16, 2018 03:51 PM
timothypaul
Mar 7, 2018 12:16 PM
Jonathan67
Jun 21, 2016 07:29 PM
kens69olds
Jul 19, 2011 09:22 AM
