Dash 86 442
Dash 86 442 to 87 dash 442
Upgrading my engine I'm my 1986 442 2 was wonder my if the gauge cluster from an 87 442 to would fit and what all things I would need from the 87 ? Cars going to go faster 85 but wanted to keep the gauges Oldsmobile
Changing from an 86 - 442 85MPH cluster to an 87 - 442 120MPH cluster should not be an issue from a bolt in stand point.... I do believe the speedometer cables and gears are the same, any GM dealer parts department should be able to verify that for you....
Its a direct swap. No changes to your 86' are needed. Hang on to the 87' cluster. They are worth some money due to one year only 120 mph speedo.
Big Mikey
May 12th, 2013 05:40 AM
DJMatthews
December 12th, 2006 06:36 AM
