Cylinder head removal
Old May 17, 2018 | 01:24 PM
2oldsguy's Avatar
I haven't been here in a while but now I need some assistance.
I have a 70 442 with a 455 that I have to remove the heads and it has power brakes.
I can not get the last left push rod out because of the booster. Is there a secret way to remove the two lower bolts that hold the booster to the firewall? I can get the top but the lower ones are a pain.
Thanks,
Joe
Old May 17, 2018 | 01:32 PM
When I replaced the booster on my 71, I used an open end wrench, reached behind the booster, and turned the nut about 1/8 turn at a time. I had to keep switching ends of the wrench as I turned the nut. It was a PITA to get the nuts off.
Old May 17, 2018 | 03:09 PM
CRUZN 66's Avatar
Olds Fever
Use a ratchet wrench such as the ones shown in the link below...
https://www.lowes.com/pd/Kobalt-7-Pi...Wrench/3362658
Old May 17, 2018 | 03:20 PM
Not sure because mine had tons of room for my skinny arms, what if you removed your wiper motor?
Old May 18, 2018 | 12:01 AM
Gerald Nickels's Avatar
Don't take the buster off just leave the push rod in head with tape holding in in place and remove the head with push rod in head.
Old May 18, 2018 | 04:28 AM
2oldsguy's Avatar
This is whtn I finally did, but I used a small spring clip to hold the push rod.
I do have a set of those ratchet wrenches but the left side is real tight.
Now that I have the heads off I am trying to decide whether to redo the iron heads or go aluminum.
Joe
Old May 18, 2018 | 11:00 AM
TripDeuces's Avatar
I'm at a loss here. I replaced the head gaskets on my 70 455 Cutlass with power brakes right on the car and never had a problem with a push rod. What am I missing?
revrory12
Oct 26, 2021 08:54 AM
wisniows
May 19, 2014 06:52 PM
jread199
Nov 11, 2012 02:54 PM
72RocketPower
Feb 9, 2006 07:46 PM
