Correct Secondary Rod Hanger
Old May 5, 2009 | 02:59 PM
captn442's Avatar
Hi Guys... What would be the correct secondary rod hanger letter for a 1971 442 Auto Trans? I think the correct carb # is 7041257 and I have all the jet & rod sizes but I can't find what the hanger should be.
Old May 5, 2009 | 03:04 PM
jensenracing77's Avatar
i don't know what your hanger size should be but if you find out and you don't have one let me know. i have many of them and if i have a double of the one you need i will send it to you. i have collected these for years and still don't have them all. a have duplicates of several of them.
Old Jul 23, 2019 | 02:00 PM
captn442's Avatar
It's been a while but I am still looking for the answer. I thought you guys with 71 W30's would know the answer.
Old Jul 23, 2019 | 05:55 PM
There is no "correct" hanger. Rochester selected the hanger individually for each carb at the factory to achieve the required flow. The hanger height only effects part throttle fuel flow on the secondaries. In all cases, when the secondary air valves are wide open, the metering rods are on the small diameter no matter which hanger is used.
Old Jul 24, 2019 | 05:55 AM
Burd's Avatar
Call Cliff in Ohio.
https://cliffshighperformance.com/
Old Jul 27, 2019 | 04:32 PM
dougherp's Avatar
Phil D.
My 71 442 (non-W-30) Auto w/AC with original carb 7041257 has a "J" hanger.
Old Jul 28, 2019 | 06:23 AM
Burd's Avatar
Dang, photoshitbucket ruined it, I can repost if you can’t read, I got the chart from a carb guy here in the D.
it gives you the part number and the 2 letter code. Cliff or Ames sells them.
Old Jul 28, 2019 | 06:27 AM
Burd's Avatar
Here’s more,
Tuffnut
Jan 14, 2019 09:09 AM
boese1978
Mar 8, 2016 03:49 PM
brown7373
Oct 22, 2014 07:35 PM
SRV8
Oct 1, 2012 06:31 AM
Twilight Fenrir
May 31, 2011 10:08 AM
