A/C System Lubrication
Old May 23, 2020 | 09:11 AM
craig442's Avatar
I'm adding all the stock A/C stuff back into my 65 442 AC Car. It's all new or refurbished. Do I add all the lubricant into the new compressor (system takes 10.5 oz), or does it need to be distributed throughout? According to the assembly manual you can add the oil to the compressor but just wanted to get some thoughts.
Thanks in advance.
Old May 23, 2020 | 07:26 PM
Are there any instructions with the new parts? If all else fails, read the instructions!!
If the parts don’t give specific procedures for adding oil, follow the service manual.
Old May 23, 2020 | 08:07 PM
craig442's Avatar
I found the service manual, it states to add 10.5 oz if the whole system was evacuated (as in my case).
Old May 23, 2020 | 08:20 PM
I have always distributed the oil.
Old May 24, 2020 | 05:10 AM
VC455's Avatar
Barely Registered
The oil's only purpose is to lubricate the compressor pistons. However, after you run it a while, some of the oil settles in the evaporator and condenser, that's why you need to put in so much--there needs to be enough extra that it can continuously circulate to the compressor.
You can distribute 30% of the oil if you feel more comfortable with that. It just replicates the state of the system a few hours into use.
Old May 24, 2020 | 05:55 AM
68442's Avatar
On an all new systems, as you stated yours is. Add the sec'ed amount to the compressor and you are good. Then run in upon start up will circulate as needed. Also be sure to use the CORRECT OIL and VISCOSITY on an R12 System.
Old May 24, 2020 | 06:52 AM
craig442's Avatar
Thanks All, I'll add the 10.5 Oz to the compressor. The paperwork with the compressor (AC Delco) said to use AC Delco P/N 15-118 oil.
442fanatic
Jun 12, 2019 06:14 AM
GCH
Oct 13, 2016 06:02 AM
AJFink
Mar 16, 2016 05:06 PM
chip-powell
Feb 1, 2016 03:39 PM
Mattia-SS
Mar 24, 2012 03:29 PM
