Broadcast sheet question
Old Feb 14, 2020 | 11:18 AM
  #41
joeyg's Avatar
On the top box (PLT. OPT 16) any ideas what it means, also on the top box far right (P P)?
Old Feb 16, 2020 | 11:55 AM
  #42
344870M's Avatar
AO1 is tinted glass. As far as the P P 2 I have no idea. My 70 W30 has this same info
Old Oct 21, 2020 | 09:56 PM
  #43
pfriesen's Avatar
Just discovering this thread now after owning a '70 Cutlass Supreme convertible for 35 years. (red exterior, white top, pearl interior, buckets, console, automatic, speed shifter gate).
My broadcast sheet includes these items that I don't know the meaning of:
Seq: 024 Mo: 03 Day: 10
Under Trim, SPCL: Z
Trim Comb: 977
Under PP: 2
Box 1: A39
The only other box with anything is 9, with U80, which I see is the rear speaker option (since removed).
Thanks for any help you can offer.
And thanks for this wonderful forum.
Old Oct 22, 2020 | 08:29 AM
  #44
69 Hurst's Avatar
Olds Fanatic
Might be able to help you with a couple of them:
I believe the sequence designates the car was the 24th unit built on Mar. 10th
A39 is Seat Belts, Deluxe front & rear, convertible
Old Oct 23, 2020 | 08:26 AM
  #45
pfriesen's Avatar
Thanks for that, Fanatic. I'll check back to see if others have anything to add.
Old Dec 1, 2021 | 05:18 AM
  #46
leftlaneonly's Avatar
Were Fisher Body W30 broadcast sheet options put on at the Oldsmobile plant or sent off to Fisher
Old Oct 3, 2022 | 03:51 PM
  #47
Bigmikey65's Avatar
I have a couple of questions about the Broadcast Card. All 1970 442”sW30’s came standard with Strato Bucket Seats. I know there are potentially 5 areas on the Broadcast Card codes that point to the vehicle having Bucket Seats : Style, Trim Combo, W30 in Box #3, A51 in Box #4 or #5 and finally the word BUCKET stamped in red ink. With buckets being standard on 442’s/W30’s and a Bench Seat being optional on 442’s/W30’s you would think that more of an effort would be needed to the workers at Fisher to point out that a Bench Seat was called for on that particular vehicle ? Are there differences in the locations of the holes drilled in the floor pan between buckets and a bench seat ? Why not a red stamp BENCH for the optional equipment instead of the red stamp BUCKET for the standard equipment ?
Old Oct 3, 2022 | 04:27 PM
  #48
Why not aent ?red stamp BENCH for the optional equipment instead of the red stamp BUCKET for the standard equipment
because they were for in plant use during production of cars, not for us to use 50 years later.
Old Oct 3, 2022 | 04:51 PM
  #49
v8al's Avatar
Registered Olds Owner
Across the Oldsmobile line bench seats were way more common than bucket seats. Even within the A-body line most cars got a bench seat. Think of all the 4 door Cutlass and stripper F-85's. So at the Fisher plant most of the time they installed bench seats with only the occasional bucket seat car.
Also there are extra brackets welded onto the floor pan for bucket seat cars.
Old Oct 4, 2022 | 05:18 PM
  #50
Precisely, plus, to the guy throwing the seats in, he doesn't care which model it is.
GreatSX
Nov 20, 2020 09:31 AM
ostricker
Apr 19, 2019 10:50 AM
35olds
May 8, 2017 05:42 AM
friesjh
Feb 19, 2016 07:39 AM
myolds
Jul 10, 2008 09:45 AM
