Ac brackets for 67 Olds 442
Old January 13th, 2011, 08:19 AM
a1fla's Avatar
Can anyone tell me if the following ac bracket cast numbers will work on 400 ci
391366
391388
398682
391188
Thanks in advance
a1fla is offline
Old January 13th, 2011, 08:40 AM
car guy
gearheads78's Avatar
I'm don't have the numbers with be but if you need the brackets I have a set that came off a 67
gearheads78 is offline
Old January 13th, 2011, 09:09 AM
oldjunkster's Avatar
I found two of the part numbers in my 1966 Parts and Accessories manual. They should be the same for a 1967.
391366 - F-85 V-8 Rear compressor bracket
391188 -F-85 V-8 Front compressor bracket - Except w/A.I.R.
Hope this helps
oldjunkster is offline
Old January 17th, 2011, 10:51 AM
a1fla's Avatar
Originally Posted by oldjunkster
i found two of the part numbers in my 1966 parts and accessories manual. They should be the same for a 1967.
391366 - f-85 v-8 rear compressor bracket
391188 -f-85 v-8 front compressor bracket - except w/a.i.r.
Hope this helps
thanks alot!
a1fla is offline
Old January 22nd, 2011, 02:22 PM
a1fla's Avatar
Hope this helps
Ac brackets:Can you tell me what these casting numbers apply to:
391188
391388
9785787
a1fla is offline
Old January 22nd, 2011, 02:31 PM
a1fla's Avatar
391188
391388
9785787
Ijust noticed from your previous post, the 391188 is the front compressor bracket, but can someone tell me the others
391388
9785787
a1fla is offline
Old January 23rd, 2011, 07:08 AM
a1fla's Avatar
Also was wondering how to decode A6 Frigidaire compressor for date code
cast number 6555302
Frigidaire sticker shows 5910486
a1fla is offline
Old January 23rd, 2011, 07:29 AM
I found this part number in my 1966 Parts and Accessories manual.
6555302 - 1966 compressor head (rear)
also, look for the below part number
6555283 - 1966 compressor head (front)
Old January 25th, 2011, 08:41 AM
Nor Cal Andy's Avatar
If you are looking for 67 AC stuff I hjave a complete setup lines everything compressor un opened I pulled it from a 67 complete... It has the 67 date code. I have all the brackets pulleys everything. If I do get rid of it Id like to sell everything complete... Send me a PM and let me know..
Nor Cal Andy is offline
Old December 6th, 2011, 11:46 AM
rum1's Avatar
A/c bracket
I am looking for a rear compressor bracket for my 67 442. The casting # is 381366. I broke mine!
Plese reply to John at rum1@comcast.net
Thanks!
rum1 is offline
Old August 15th, 2014, 06:01 PM
Biff2177's Avatar
67 442 a/c brackets
I currently have a/c brackets and compressor from a 68 toronado but belt doesn't line up. Looking for brackets/compressor for 67 442.
Biff2177 is offline
Old August 15th, 2014, 06:37 PM
lemoldsnut's Avatar
I might have it email me direct and I will check over the weekend
Larry
lemoldsnut@aol.com
lemoldsnut is offline
BeenThere
March 1st, 2015 10:21 AM
ros6872
November 18th, 2014 06:27 PM
olddaz
August 27th, 2014 06:39 PM
ros6872
July 18th, 2014 04:08 AM
ERIC27
March 3rd, 2013 11:14 AM
Quick Reply: Ac brackets for 67 Olds 442
