Ac brackets for 67 Olds 442
Old Jan 13, 2011 | 08:19 AM
a1fla's Avatar
Can anyone tell me if the following ac bracket cast numbers will work on 400 ci
391366
391388
398682
391188
Thanks in advance
Old Jan 13, 2011 | 08:40 AM
gearheads78's Avatar
car guy
I'm don't have the numbers with be but if you need the brackets I have a set that came off a 67
Old Jan 13, 2011 | 09:09 AM
oldjunkster's Avatar
I found two of the part numbers in my 1966 Parts and Accessories manual. They should be the same for a 1967.
391366 - F-85 V-8 Rear compressor bracket
391188 -F-85 V-8 Front compressor bracket - Except w/A.I.R.
Hope this helps
Old Jan 17, 2011 | 10:51 AM
a1fla's Avatar
Originally Posted by oldjunkster
i found two of the part numbers in my 1966 parts and accessories manual. They should be the same for a 1967.
391366 - f-85 v-8 rear compressor bracket
391188 -f-85 v-8 front compressor bracket - except w/a.i.r.
Hope this helps
thanks alot!
Old Jan 22, 2011 | 02:22 PM
a1fla's Avatar
Hope this helps
Ac brackets:Can you tell me what these casting numbers apply to:
391188
391388
9785787
Old Jan 22, 2011 | 02:31 PM
a1fla's Avatar
391188
391388
9785787
Ijust noticed from your previous post, the 391188 is the front compressor bracket, but can someone tell me the others
391388
9785787
Old Jan 23, 2011 | 07:08 AM
a1fla's Avatar
Also was wondering how to decode A6 Frigidaire compressor for date code
cast number 6555302
Frigidaire sticker shows 5910486
Old Jan 23, 2011 | 07:29 AM
I found this part number in my 1966 Parts and Accessories manual.
6555302 - 1966 compressor head (rear)
also, look for the below part number
6555283 - 1966 compressor head (front)
Old Jan 25, 2011 | 08:41 AM
Nor Cal Andy's Avatar
If you are looking for 67 AC stuff I hjave a complete setup lines everything compressor un opened I pulled it from a 67 complete... It has the 67 date code. I have all the brackets pulleys everything. If I do get rid of it Id like to sell everything complete... Send me a PM and let me know..
Old Dec 6, 2011 | 11:46 AM
rum1's Avatar
A/c bracket
I am looking for a rear compressor bracket for my 67 442. The casting # is 381366. I broke mine!
Plese reply to John at rum1@comcast.net
Thanks!
Old Aug 15, 2014 | 06:01 PM
Biff2177's Avatar
67 442 a/c brackets
I currently have a/c brackets and compressor from a 68 toronado but belt doesn't line up. Looking for brackets/compressor for 67 442.
Old Aug 15, 2014 | 06:37 PM
lemoldsnut's Avatar
I might have it email me direct and I will check over the weekend
Larry
lemoldsnut@aol.com
BeenThere
Mar 1, 2015 10:21 AM
olddaz
Aug 27, 2014 06:39 PM
ros6872
Jul 18, 2014 04:08 AM
ERIC27
Mar 3, 2013 11:14 AM
