71 442 engine build
Old Jan 2, 2008 | 04:02 PM
rml442's Avatar
robert
71 442 engine build
have a 1971 olds 442 and the engine is being built, 30 over, new cam and such. question is what manifold and carb combo to fit under a ram air hood? would like to use edlebrock. 750cfm carb electric choke. what do i need guys?
Old Jan 2, 2008 | 05:47 PM
2blu442's Avatar
Intake, carb under OAI hood
From what I've heard you'll have to stick with a factory intake or the Edlebrock O4B which has been out of production for years. The O4B is aluminum but doesn't flow significantly better than the factory cast iron piece. There is an aftermarket air cleaner top that doesn't have a flapper in it, that will allow you to put on a taller intake. I tried a performer intake and then just glued a foam ring on the metal air cleaner base, I didn't install the plastic lid with the flapper. It doesn't look as nice, but functioned. Most of the guys on this site are partial to Quadrajets. If you get a good carb of the correct vintage and have it professionally rebuilt I think you'll be happy with it. My 2 cents worth. John
Old Jan 3, 2008 | 06:38 AM
Oldsguy ran an O4B on his 69 Delta 88. It was a good intake. The worst part of it is that you can't run an HEI distributor with it.
Old Jan 30, 2008 | 02:10 AM
coopsie442's Avatar
ill say the edelbrock torker intake and the holly carb! haha
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
805cut
May 3, 2012 08:11 PM
NightStalker
Jan 1, 2011 03:05 PM
69 442 protour
Dec 9, 2006 09:25 PM
