70 442 Tires
Old Aug 21, 2008 | 07:51 AM
69'442's Avatar
70 442 Tires
I have a set of 14" SS1 rims for my 70 442. What size and brand tires do you guys recommend? I would like to keep it somewhat stock. Thanks
Old Aug 21, 2008 | 10:20 AM
Unless you plan to lower the car, any tire less than about 27" in diameter leaves too much daylight in the wheelwells, in my opinion. Unfortunately, the options for 14" tires in these diameters are very limited. BFG, Goodyear, and Firestone all sell 225/70-14s that are about 26.4" O.D. Ideally you'd want 235/70-14s, but I can't find anyone who sells that size anymore. Coker Tire sells a cool looking 225/75-14 redline radial (27.3" O.D.) but at $193 each these tires apparently use solid gold belts.
Old Aug 23, 2008 | 10:47 AM
Stock means you're going back to bias ply tires.
I could have done that too, but I went for radials because of the advantages of less rolling resistance and better handling.
Unless you plan to lower the car, any tire less than about 27" in diameter leaves too much daylight in the wheelwells, in my opinion. ......... Coker Tire sells a cool looking 225/75-14 redline radial (27.3" O.D.) but at $193 each these tires apparently use solid gold belts.
I went with 225/70 14's. It gives the car a nice aggressive look and puts a nice amount of rubber surface on the road. Joe is right about Coker, they're pricey. But you can pick and choose from other suppliers. I think there is a bigger market happening out there for wider and lower profiles than ever before. But, I agree with Joe (again) that you don't want to make the car look goofy.
And the last thing you have to pay REAL attention to, is your SS1 wheels might not be a wide enough rim to put wide tires on. Check with the tire manufacturer you are going with to find out the minimum wheel width and offset needed to make them work on your car. If your P05 SS1's won't do the trick, you can get wider ones (14X7 and 15X8) but they cost a pretty penny. Here's a link to a a site that sells them new:
www.wheelmasterclassics.com Clik on "wheel vintiques". About 3 pages in there's the SS1 Chrome c/w center caps.
Last edited by Allan R; Aug 23, 2008 at 10:49 AM. Reason: change directions from web link
Old Aug 26, 2008 | 02:35 PM
68Tom's Avatar
Uniroyal Tiger Paws come in 235/70-14.
Old Aug 27, 2008 | 06:35 AM
It doesn't matter what size you get as long as you run white letter out! They could even be Wal-Mart brand Generals!
Old Aug 27, 2008 | 06:57 AM
Good info, thanks. The 14" tires are getting harder and harder to find.
Old Aug 27, 2008 | 06:58 AM
The Uniroyal Tiger Paw is actually rated rather well at tirerack.com I think is has 7s in most of its categories. It is also reasonably priced. Best of all, it is black wall/white letter!
Old Aug 27, 2008 | 07:26 AM
68Tom's Avatar
No problem, Joe. I'm going to be putting them on my '69 Camaro, as many '69s originally came with Tiger Paws (different font for the white lettering, but I think it still looks fairly vintage....)
Seeing as I'm now keeping my 442, I think I'll eventually put some redline radials on it despite the ridiculous cost.
Old Aug 27, 2008 | 12:57 PM
69'442's Avatar
Thanks for all the info guys. I can only find the Uniroyal Tiger Paws in a 235/60-14. I can't find any 235/70-14's. Where did you find them? If I can't get them I will probably go with the BF Goodrich 225/70-14 with RWL. I think they will look good and they are reasonable.
Old Aug 27, 2008 | 01:22 PM
Did you try tirerack.com?
Old Aug 27, 2008 | 02:20 PM
69'442's Avatar
Yes, I only see the 235/60-14's available on their website so I called and they said they can't get the 235/70-14's from any of their suppliers.
Old Aug 27, 2008 | 03:41 PM
68conv455's Avatar
You can upgrade those wheels with new SS1 style 15x7's for about $160 each (set of 4). Then you can run common 235/60/R15's to keep the stock appearance.
Tires are part of the overall look of the car. Don't go smaller than this on a musclecar.
Old Aug 27, 2008 | 06:13 PM
GoodOldsGuy's Avatar
442=A perfect 10
How about a nice set of redlines??? Still want the white letters? Check out this site www.dbtires.com I bought a set of wide whites for my 58 vette and they look great and ride smooth. Just my .02.
Regards,
Fred
Old Sep 1, 2008 | 02:43 AM
442much's Avatar
Try this site. You can compare sizes.
http://www.1010tires.com/TireSizeCalculator.asp
Old Oct 18, 2008 | 11:26 AM
dkatz's Avatar
Down South
Go to 15
take my advice go to 15" and live a little. take a look at these torque thrusts and tell me if the move to 15" is not worth it.
Old Oct 18, 2008 | 12:58 PM
Very pretty post coupe. I see you decided to go painted roof instead of vinyl. Wheels look fine. Personally I think that most aftermarket wheels don't give the same visual as the SS1, SS11 or SS111, but that's my opinion. BTW, the all 3 of the wheel types mentioned are available in 15" rims. You've got a nice car and the chrome certainly doesn't make me look the other way. After all, it's an Olds.
Old Oct 21, 2008 | 05:17 PM
FL1970442's Avatar
1970 rims
All 70 442s came with SSII rims painted the color argent, some people refer to this color as argent "silver" or "grey". Although argent is considered a color. In 1970 the wheels did not match the color of the car, as in other years. I run 225 70R14s on my 70 442 and they look fine.
jnaarnold
Sep 12, 2017 08:09 PM
navvet
Feb 3, 2014 02:44 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
Bob Lynch
Jun 25, 2009 02:36 PM
