67 442 rally pac gauges
Old November 28th, 2015, 05:27 PM
welchtec's Avatar
Post 67 442 rally pac gauges
have 67 442 conv with rally pac gauges they have been worked on some time in the past. I ordered a new printed circuit for it . the amp meter has a shunt on it and so does the temp gauge the oil press does not. in the factory manual , it shows one on the oil and temp, but not the amp and the one on the temp are not on the correct post . also in the factory manual there is a single short lead wire coming off one of the post , but does not show or tell where it goes . does any one have aviable a good wiring diagram or any good pictures showing back of panel 1967 442 rally pac gauges thanks
welchtec is offline
Old November 29th, 2015, 07:56 PM
Majored in rear tire demo
2Olds4U's Avatar
Welcome to CO!
The "shunts" are on the temp and O/P gauges, not the ammeter.
As far as the jumper wire, I, like you obviously did, took it apart without taking notes. I believe it goes from the center temp terminal to the o/p gauge, but not certain. The chassis manual does not, anywhere, say where it leads to.
I can check tomorrow to see where I out it, as I believe I pretty much exhausted all the possibilities, but not tonight. The Pats are on!
BTW, you may want to post in the noobie section and introduce yourself and your ride. And we like (demand) pictures!
2Olds4U is offline
Old November 30th, 2015, 06:13 PM
welchtec's Avatar
thanks for the feed back. there was no wire on the temp gauge but can see in factory manual but cannot tell were it ran too. on my temp gauge the shunt runs between the vertical upper and lower post looking at the back of the gauge in the panel, the factory manual shows the shunt running vertical between the right post and the left post and the short wire with ends on it , one end on the lower vertical post but cannot tell where it connects.
welchtec is offline
Old November 30th, 2015, 08:30 PM
steverw's Avatar
You should try contacting Ron Roth. He is the resident 66/67 IP expert. I havnt seen any post from him lately, but im sure hes still around. He also restores them and does excellent work. Search his name in the search bar at top.
steverw is offline
Old December 2nd, 2015, 06:24 PM
2Olds4U's Avatar
Do you have this page in your manual?
And, steverw, I did ask Ron, since he did the dash for me. He had no idea where it went. I don't think he disassembles the clusters, just removes them.
2Olds4U is offline
Old December 2nd, 2015, 07:13 PM
welchtec's Avatar
no it does not. trying to print picture. thanks welchtec
welchtec is offline
firefighter5174
May 16th, 2014 09:21 PM
firefighter5174
January 23rd, 2014 10:07 AM
firefighter5174
May 15th, 2013 05:41 PM
69442
March 21st, 2013 01:09 AM
69442
October 13th, 2011 05:06 AM
Quick Reply: 67 442 rally pac gauges
