66-67
Can the instrument panel from a 67 Cutlass (the gray part that the switches and controls attach to) be a straight up swap on a 1966 442? If not a straight up swap what would be needed to complete the project?
They're identical except for the wiper switch mounting hole.
https://classicoldsmobile.com/forums...s-67-dash.html
On a 1966 442 instrument panel is there a cut out for the air conditioning outlet that is covered by the radio face plate? I am looking to buy a used panel but in the pictures there are three squares cut-out, one for the radio, one for the climate control, and I assume the air conditioning outlet. Is this the way all instrument panels were made? Thanks.
Are the delete plates hard to find? The reason I ask is because my dash does not have the delete plates. There is an aftermarket radio and a metal sign that reads "BOSS" screwed to the dash, so I would need the delete plates.
Instrument Panel
If you need any help or want to buy a restored IP
I have some for sale.
Send me an email address and I will show you what I am talking about.
Ron
Ron
Email address is Wahoo22@aol.com
Looking for a restored IP for a 1967 Cutlass
Hi Ron -
I'm in need of restoring or replacing my current IP in my 1967 Cutlass - do you have one? / What's the cost? Email is:
dantodd@kc.rr.com
Thanks in advance!
dantodd@kc.rr.com
Thanks in advance!
