66-67
Old May 4, 2011 | 01:25 PM
Thomas Simcich's Avatar
66-67
Can the instrument panel from a 67 Cutlass (the gray part that the switches and controls attach to) be a straight up swap on a 1966 442? If not a straight up swap what would be needed to complete the project?
Old May 4, 2011 | 03:44 PM
OLDSmobility's Avatar
They're identical except for the wiper switch mounting hole.
https://classicoldsmobile.com/forums...s-67-dash.html
Old May 5, 2011 | 05:49 AM
66-67
Is the area around the steering column larger on a 67 than a 66? I am trying to mate a 67 instrument panel to a 66. Thanks
Old May 5, 2011 | 07:30 AM
Are you referring to the metal dash? The instrument panel doesn't extend down to the opening in the dash for the steering column.
Old May 9, 2011 | 06:41 AM
Can I swap over to a 67 wiper switch to make the conversion easier?
Old May 13, 2011 | 07:04 AM
On a 1966 442 instrument panel is there a cut out for the air conditioning outlet that is covered by the radio face plate? I am looking to buy a used panel but in the pictures there are three squares cut-out, one for the radio, one for the climate control, and I assume the air conditioning outlet. Is this the way all instrument panels were made? Thanks.
Old May 13, 2011 | 07:29 AM
Ranzan's Avatar
Getting There
yes they are all made like that with delete plates for whatever is not used
Old May 13, 2011 | 10:28 AM
Are the delete plates hard to find? The reason I ask is because my dash does not have the delete plates. There is an aftermarket radio and a metal sign that reads "BOSS" screwed to the dash, so I would need the delete plates.
Old May 20, 2011 | 03:37 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Instrument Panel
If you need any help or want to buy a restored IP
I have some for sale.
Send me an email address and I will show you what I am talking about.
Ron
Old May 21, 2011 | 06:28 AM
Email address is Wahoo22@aol.com
Old Jun 12, 2011 | 06:58 AM
danimal442's Avatar
Looking for a restored IP for a 1967 Cutlass
Hi Ron -
I'm in need of restoring or replacing my current IP in my 1967 Cutlass - do you have one? / What's the cost? Email is:
dantodd@kc.rr.com
Thanks in advance!
