5.1” 72 350 water pump numbers
Old May 21, 2021 | 12:01 PM
jozw30's Avatar
Anyone have a replacement part number for this 1972 442 I’m working on? 350 no ac, 5.1” water pump.
having a hard time finding one.
I ordered a non-AC WP on Amazon and it’ too long...the ones listed on Rock auto don’t give the length?
Old May 21, 2021 | 02:13 PM
Rocket Launcher's Avatar
From Rock Auto site:
AIRTEX AW773 {Click Info Button for Alternate/OEM Part Numbers230336, 230608, 230899, 384783, 384786, 388182, 388183, 398681, 404584, AW774, WP343} Includes Gasket; 5.1" Hub Height Info
w/o A/C or Heavy Duty Cooling; w/o Outside Air Injection (Only 1 Remaining)
Old May 21, 2021 | 02:49 PM
Given all the well documented errors in the RockAuto on-line catalog, I wouldn't recommend using that as an authoritative guide for Olds part numbers.
Try this. Also note the difference between part number and casting number.
Short answer is P/N 388182 for non-A/C and P/N 388183 with A/C. You'll note that RA lists the same Airtex AW773 pump as an interchange for both A/C and non-A/C applications. And yes, that 388183 A/C pump is 5.1" long.
Old May 21, 2021 | 07:14 PM
Mr Shifty Sidney's Avatar
I have a factory correct waterpump core. PM if interested. Besides the height of waterpump also make sure outlets are the correct sizes.
Don W
1970VistaCruiser
Apr 11, 2021 09:18 PM
4424me
Jan 24, 2016 12:41 PM
jlauffer
Sep 27, 2015 05:08 PM
btbradley12
May 1, 2014 03:30 PM
HWYSTR455
Jun 30, 2013 07:41 AM
