455 headers vs stock manifolds
The answer depends on what you plan to do with the motor. Headers will always give more power, at the expense of more aggravation, reduced ground clearance, overheated starter, etc. Personally I always use headers in a performance application and I expect the problems that go with them.
Hi. personally, to keep my car looking stock, I took the factory "W"and "Z" exhaust manifolds and port matched them, using an exhaust gasket as a template.The same die grinder, can be used to smooth out the "popcorn" nodules along the inside mold line. then I smoothed the curves as much as I could reach, from the head side, inward. you will see more increase in HP output by upsizing the exhaust pipes. Mine are 2.25" Adding A crossover-balance tube, helps breathing too. Magnaflow dual exhaust 18" mufflers will keep the car from calling the cops on you. Anyway that's my set-up.
I want the car to look stock but I want to upgrade the performance. I always planned on going headers until I heard something bout 445running better with manifolds. Glad to hear it doesn't I want headers.
What's a good header to use that won't break the bank?
When this question is asked you will get many different answers. There are many threads on here about headers. Most have had good success with Hooker, Dougs, and Heddman.
I have not done it but Greg gessler Bill Travto and others have used porting to flow much better. Greg has it on his web site there is also
boneheadperformance they do extruda hone I would like to take a set
of the Ram air resteration manifolds and work them .
http://www.gesslerheadporting.com/ge...d!opendocument
www.boneheadperformance.com
http://highperformanceolds.com/phpbb2/index.php check out some of bull builds he has one with headers and manifolds and the power loss
kevin.horton
July 7th, 2011 09:49 AM
