442 rad over flow can?
Old March 8th, 2013 | 08:28 PM
Bernhard's Avatar
Did the 69 442/cutlass ever come with a factory radiator over flow catch can/bottle/container?
If they did does any one have pictures
Old March 8th, 2013 | 08:40 PM
ROCKET VAPOR's Avatar
Lance
'69 only had a windsheild washer bottle from the factory. Nothing for the radiator other than a overflow hose. Hope this helps
Old March 8th, 2013 | 09:37 PM
rocketraider's Avatar
Oldsdruid
In a word, no. That option did not appear until 1971.
If you want one, you can probably adapt the 71-73 jug but it is not factory, if that's what you're after. Or you can get an aftermarket one at about any parts store.
If you're having coolant overflow problems, do not fill the radiator to the cap neck. Without a recovery tank you HAVE to leave about 3" of space between cold coolant level and the cap for the system to function and not puke out coolant. Your radiator should have a "FILL COLD" mark on the cap side tank.
CLcutlass
Paint
28
February 6th, 2020 06:57 PM
1971 442 convert
August 22nd, 2012 08:50 PM
Sid
September 27th, 2010 08:55 AM
slowolds
Hurst/Olds
June 15th, 2010 06:09 PM
82 Grocery Getter
Site Help
June 2nd, 2009 06:24 AM
