4 spoke steering wheel
Old Jun 22, 2021 | 05:10 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Found this used OEM steering wheel for sale online. The seller states the wheel will fit Olds 442's, Cutlass, Toronado, F85, etc. from 1966-1977. Is this correct as I don't want to buy it and find out it doesn't fit my 69 442.
Thanks for your help.
Old Jun 22, 2021 | 05:42 PM
7314haywood's Avatar
I saw this yesterday and not today. I assumed it was sold as I was thinking on buying it.
Old Jun 22, 2021 | 06:04 PM
The 1969-up steering columns are all the same at the upper end. It will fit any of them.
Old Jun 22, 2021 | 07:05 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Thanks, guys. So I guess the seller was only wrong about the 66-68 models. Glad I asked!
Old Jun 22, 2021 | 07:37 PM
68 is 3 spoke. I actually like the 4 spoke better and I can hear now at car shows. He has the wrong year wheel.
Old Jun 23, 2021 | 04:55 AM
It can be used on 1968-earlier cars, but the steering column on those cars is smaller in diameter because the key is in the dash, and the hub of the wheel will be larger than the column. It works but looks goofy.
Old Mar 11, 2022 | 04:23 PM
Wsbkmike's Avatar
69 Olds 442 Guy
Well just got around to install the steering wheel. The splines in the hub don't connect/line up with the splines on the steering column as they are on opposite ends of each other. So, at least this steering wheel doesn't fit a 69 442. Ugh.
Old Mar 11, 2022 | 04:27 PM
I have no idea what splines "on opposite ends" you are talking about. I have personally used that wheel on 1969 steering columns with no issues. The top end of GM columns is pretty much identical from 1969 into the early-90s. Heck, I've even got one of those wheels on a 1988 Firenza steering column.
ByronF
Jan 4, 2018 05:35 AM
rreiko1969
Oct 30, 2015 09:46 AM
RAMBOW
Mar 7, 2011 03:18 PM
bjamincarr
Mar 27, 2008 05:16 PM
<Stanishj>
Nov 26, 2004 04:33 PM
