200R4 Overdrive with Dual Gate Shifter???
Has anyone done this in a 1972 442? Was it a kit or a fabrication?
At this point, I am gathering the parts.
Also, anyone have a 200R4 core?
TIA
TIA
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Hurst briefly sold an aftermarket four speed dual gate in the 1980s. When one shows up on ebay now it will usually sell for more than an original 60s unit. These units are highly coveted by the Buick GN crowd.
Shifter parts
There's a company making the detent that will fit a standard automatic floor shifter. I had talked with them a couple years ago and they were having trouble trying to make one for a dual gate. I'll dig around and see if I can come up with their web address. But that still wouldn't resolve the top plate. John
Last edited by 2blu442; November 9th, 2008 at 09:07 PM. Reason: Clarifying a comment
Shifter
OK, I've not used their products but have been told they're good. They advertise an automatic shifter converstion for the 4 speed automatic that will fit the factory console. I don't see the dual gate but they do have the single gate for applications from 1964-72. John
http://www.shiftworks.com/cutlas.htm
I've seen the Shiftworks kit installed in a 70-72 factory dual gate. Its, ah, OK. Not great, but OK. The kit puts OD in the formerly neutral position. Neutral and reverse are now crammed into what used to be reverse alone. The problem is that without a new top plate, you have no other choice.
ah64pilot
May 29th, 2012 03:04 AM
