1972 4-4-2 questions
Old May 9, 2014 | 09:09 AM
Diego's Avatar
Hi, someone posted a query in a diecast site and wants to know whether the rocker panels should be painted or chrome.
I suggested, based on literature (http://oldcarbrochures.org/NA/Oldsmo...e-Dealer-SPECS) that if it was a Cutlass, it should have no rockers, but if it was a Cutlass S, it should have chrome rockers.
Does this sound right?
Old May 9, 2014 | 09:23 AM
vette442's Avatar
There is no rocker stainless trim on any '72 W-29 442s, whether a car was derived from a Cutlass, Cutlass S or Cutlass Supreme model level.
Terry
Old May 9, 2014 | 09:26 AM
Diego's Avatar
I'm confused now.
So no 1972 4-4-2s received rocker moldings?
Old May 9, 2014 | 09:27 AM
vette442's Avatar
Originally Posted by Diego
I'm confused now.
That's correct. No rocker moldings at all, just like in 1970 and 1971. Just painted.
Terry
Old May 9, 2014 | 10:08 AM
stevengerard's Avatar
Terry is correct as far as have researched it and know - for what its worth
Old May 9, 2014 | 10:26 AM
Terry
X2
Any 72 2 door coupe (HT or Post) could be a 442, along with ANY of the available engines for the year. The W29 package called for appearance and handling changes that differentiated it (eg: grills/stripes/trim) and made some features (such as suspension) standard when the other models offered them as options.
Note: On CS lineup, only the vert was available to receive 442 option
The 72 442 W30 major upgrades were the L77 engine, dual exhaust and cutout rear bumper. BTW, the car in my sig pic is a clone W30 and has the rocker stainless.
Old May 9, 2014 | 10:43 AM
Diego's Avatar
The info in the literature doesn't show the rockers to be deleted when equipped with the W29 package. Interesting....
Old May 9, 2014 | 11:14 AM
Actually it does if you look at the side pictures. Just you have to look carefully.
Old May 9, 2014 | 11:31 AM
Diego's Avatar
I meant the literature (link) that I posted.
Old May 9, 2014 | 12:12 PM
Yes, you'd be correct on that. But keep in mind that that SPECS guide didn't list every component change, just the highlights to generate sales. There was much more than just a few things that separated the W29 from the other Cutlass models. If you use the same website, open the 1972 full model lineup, the picture I posted is also located there, but the rocker is not a clearly defined as a result of the scanned image.
http://www.oldcarbrochures.com/stati.../dirindex.html
Old May 9, 2014 | 12:25 PM
72 w29 all green's Avatar
Here Diego; this should help. It's from the '72 Inspector's Guide. If you squint hard enough , you will find the deleted items for W29.
Old May 9, 2014 | 01:21 PM
Diego's Avatar
Thanks . . . thanks great!
Old May 9, 2014 | 01:23 PM
Joe, thanks!
I was looking at the Inspectors guide but missed that page.
oldfarmall
26
Mar 22, 2025 06:22 AM
1972cutty
Brakes/Hydraulic Systems
May 4, 2011 06:20 AM
mryoung4815
Aug 17, 2010 05:39 AM
455nut
Jul 15, 2009 07:00 AM
jtsautos
Jul 11, 2009 04:10 PM
