1972 350" block, intake, carb, distributor #'s
Old Feb 19, 2009 | 10:46 AM
Rohebo's Avatar
I will be inspecting a small block 442 in the next week or so and I'd like to have all casting/stamped #'s to verify original components (or not) under the hood.
I know the heads are casting 409147 [or 7(subscript)A], but I can't find any info. on the block, intake or exhaust manifolds (or stamped #'s for carb or distributor either!).
So, if anyone has any or all of this info. please share it with me. And just curious if any of these other components have the dual methods of id like the heads do (big # as well as small #'s).
And also what the code should be for a '72 turbo 350.
I'm ok on VIN locations and date code identification.
I really did try a search on the tech section, but the info on small blocks had mostly holes in it.
Thanks again,
John
Old Feb 19, 2009 | 11:27 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
The trans case will have a vin derivative stamped above the trans pan lip.
Also, a silver I.D. tag on the passenger side.
There are date codes cast into the heads, with little fake screw bosses around the numbers. I believe they are above the exhaust ports.
Old Feb 19, 2009 | 11:29 AM
There are a couple good posts on the site here of us grilling ebay fakes.
Old Feb 20, 2009 | 06:39 AM
agtw31's Avatar
72 small block 442's are cutlasses,unless they have a build sheet showing the w-29 option on it.
i would hold out for a 72 U code(455) 442,instead of a small block one.you can find really nice ones in the 15-20k range.
or youd be better off just buying a clean 72 cutlass and putting 442 emblems and stripes on it yourself.
Flye
Apr 4, 2013 06:29 PM
Dave Siltman
Sep 28, 2012 12:02 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
svnt442
Jul 17, 2011 04:43 PM
