1970 w30 intake
Old Dec 23, 2020 | 10:50 PM
bear442's Avatar
1970 w30 intake
Does any one have a clue as to why there is a slot instead of a bolt hole on the driver side of the w30 intake?? Maybe Joe P. can answer this one. I believe it is the third bolt position.
Old Dec 24, 2020 | 04:49 AM
rob1960's Avatar
All the Olds v8s have that slotted hole in the 3rd location, small or big block, cast iron or aluminum! Not sure why, maybe something for assembly purposes on the line, like it maybe was the first bolt installed??. It is the near hottest part of the intake, the exhaust cross-over, but they didn't do on the pass side.
Old Dec 24, 2020 | 06:43 AM
jensenracing77's Avatar
I have always wondered this myself. I always figured it was an assembly thing for high volume production but really have no clue why if that is it.
Old Dec 24, 2020 | 09:38 AM
I assumed the slot was the "tight tolerance" hole that locates the intake fore/aft. The other bolt holes are oversize clearance holes. The slot is required to keep the hole tight in the fore/aft direction but still allow tolerance side-to-side since the heads are what locate the intake in that direction.
Old Dec 24, 2020 | 01:01 PM
That makes lots of sense Joe
Old Dec 28, 2020 | 07:23 PM
bear442's Avatar
That kind of what I thought but wasn't sure, Thanks for your response Joe.
69Chrgr
May 15, 2020 06:35 AM
1970442
Feb 7, 2016 06:29 AM
joesw31
Oct 18, 2015 09:26 AM
joesw31
Jul 11, 2015 12:08 PM
gaerte04
Sep 22, 2010 08:52 AM
