1970 442 W30
Old September 2nd, 2007, 06:58 PM
mroy0404's Avatar
1970 442 W30
Hi Guys
I'am new to this forum and would like to start by saying hello to all.
Well I finally done it, bought my friends dads car(1970 442 W30) in mint condition, it still has black paint on the under side. Really can't find rust on this car if I wanted too. This car is near perfect!!!!
Anyhow it has this problem, when it sits over nite just can't seem to start it unless gas is poured in the carb. Has anyone seen this and fixed it.
Thanks for your time guys.
Mike Roy in Canada
mroy0404 is offline
Old September 2nd, 2007, 11:12 PM
mr-tom's Avatar
probably need a new accelerator pump i had the same problem ended up rebuilding the carb
mr-tom is offline
Old September 3rd, 2007, 07:02 AM
Tom Servo's Stunt Double
texasred's Avatar
Carb or fuel pump.....
Before you crank it in the morning, remove the air cleaner, look into the carb, and pump the accellerator a few times. If you see gas squirting in, it's probably the fuel pump. If there's no gas, it's probably the carb.
C.J.
texasred is offline
Old September 3rd, 2007, 08:18 AM
It's also possible that this car has the infamous Qjet leaking well plugs.
joe_padavano is offline
Old September 3rd, 2007, 08:57 AM
mroy0404's Avatar
poor starting
I removed the air cleaner and pumped the accellerator a few times and no gas squirting in. I guess the carb(quadra-jet) will need a rebuild along with epoxy on well plugs.
Thanks guys
mroy0404 is offline
Old September 3rd, 2007, 09:23 AM
texasred's Avatar
That's what I'm thinking.
If that's the original carb and you have someone else do the work, make sure you get it back...that one's worth some coin.
C.J.
texasred is offline
Old December 30th, 2011, 12:08 PM
Olds Nut
m455sx's Avatar
Do you still have the car if so i would like to see pics
m455sx is offline
Old December 30th, 2011, 12:30 PM
Rickman48's Avatar
And know if above suggestions fixed the problem!
Rickman48 is offline
70-442-W30
July 30th, 2016 04:27 PM
halfmoontrail
July 22nd, 2013 06:51 AM
Nickyloves442s
October 24th, 2012 04:55 PM
myolds
Drivetrain/Differentials
July 9th, 2008 05:58 AM
Max
April 12th, 2008 08:38 AM
Quick Reply: 1970 442 W30
