1970 442 W30
Old Sep 2, 2007 | 06:58 PM
mroy0404's Avatar
1970 442 W30
Hi Guys
I'am new to this forum and would like to start by saying hello to all.
Well I finally done it, bought my friends dads car(1970 442 W30) in mint condition, it still has black paint on the under side. Really can't find rust on this car if I wanted too. This car is near perfect!!!!
Anyhow it has this problem, when it sits over nite just can't seem to start it unless gas is poured in the carb. Has anyone seen this and fixed it.
Thanks for your time guys.
Mike Roy in Canada
Old Sep 2, 2007 | 11:12 PM
mr-tom's Avatar
probably need a new accelerator pump i had the same problem ended up rebuilding the carb
Old Sep 3, 2007 | 07:02 AM
texasred's Avatar
Tom Servo's Stunt Double
Carb or fuel pump.....
Before you crank it in the morning, remove the air cleaner, look into the carb, and pump the accellerator a few times. If you see gas squirting in, it's probably the fuel pump. If there's no gas, it's probably the carb.
C.J.
Old Sep 3, 2007 | 08:18 AM
It's also possible that this car has the infamous Qjet leaking well plugs.
Old Sep 3, 2007 | 08:57 AM
mroy0404's Avatar
poor starting
I removed the air cleaner and pumped the accellerator a few times and no gas squirting in. I guess the carb(quadra-jet) will need a rebuild along with epoxy on well plugs.
Thanks guys
Old Sep 3, 2007 | 09:23 AM
texasred's Avatar
That's what I'm thinking.
If that's the original carb and you have someone else do the work, make sure you get it back...that one's worth some coin.
C.J.
Old Dec 30, 2011 | 12:08 PM
m455sx's Avatar
Olds Nut
Do you still have the car if so i would like to see pics
Old Dec 30, 2011 | 12:30 PM
Rickman48's Avatar
And know if above suggestions fixed the problem!
70-442-W30
Sep 2, 2024 11:47 PM
halfmoontrail
Jul 22, 2013 06:51 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
myolds
Drivetrain/Differentials
Jul 9, 2008 05:58 AM
Max
Apr 12, 2008 08:38 AM
