Click Here
SSII Argent Silver rattle can option....Rustoleum Soft iron
Old March 28th, 2017, 11:19 PM
shamusj's Avatar
I needed a quick solution for my extra set of rims- None of my local places had the proven paints in stock so I tried Rustoleum Universal Metallic rattle can. Seems a shade darker than original yet really nice low sheen and good metallic mix. In case you can't find the other rustoleum products or duplicator cans...this works.
Please excuse the crappy paint job....these are roller wheels....fast and ugly was the goal.
shamusj is offline
Old March 29th, 2017, 06:59 AM
Looks pretty good!
I've been happy with the Rust-oleum products I've used.
Olds64 is offline
Old March 29th, 2017, 07:33 AM
stevengerard's Avatar
Rust-oleum also makes a Silver "Hot Rod" wheel paint that is almost a perfect match.
Left - rim unpainted sandblasted
Top right Argent Silver
lower right Rust-oleum
stevengerard is offline
Old March 29th, 2017, 06:04 PM
Paladin31's Avatar
Hey Steven, what color code/SKU# is the Rust-O-leum you mentioned?
TIA,
Brett
Paladin31 is offline
Old March 29th, 2017, 08:12 PM
Rust-Oleum 248930 Automotive 11-Ounce High Performance Wheel Spray Paint, Graphite
Amazon Amazon
Old March 29th, 2017, 08:55 PM
Paladin31's Avatar
Paint
thanks Steven
at $11 a can from Eastwood for Argent silver, which I don't really care for
this is only $34 for 6 cans on amazing. About half the cost.
excellent
Brett
Old March 29th, 2017, 09:15 PM
No problem but as an FYI you really only need a can or two at the most. I did 8 rims the other day with a few thin coasts of the rust-oleum and then at least a couple of coats of Argent. Each rim has to have 5 -7 thin coats on them and I still have paint left in each of the cans.
I bought 4 can's originally of the Argent as somewhere it said you will need a can per wheel - not unless you plan on painting the wheel ever day for a year.
Same goes for the engine paint. I think they recommended 4 cans of the blue. I might have used 1 1/4.
Old March 29th, 2017, 10:00 PM
Paladin31's Avatar
Paint
First I apologize Shamus for walking on your thread
Steven you paint 4/5 base coats of rustoleum,then paint over that with argent?
Old March 30th, 2017, 06:10 AM
yes, but as you can see from the images above (Including the color ShamusJ Uses) the Rust-oleum looks perfect on its own. Some may say it looks closer to the Argent color of the early 70s than the Argent itself. You can see in my pic the top rim is darker. I'm fine with a darker color as the darker Argent goes well with the colors of my cars. But the Rust-oleum its a perfect match for a bit lighter variation. I have seen light colored rims and even darker colored that i have - I'm sure it all depended on the batch of the paint, fading, thickness of coverage etc.
I found an Argent power-coat color too. My W30s have rims I powder-coated first then misted with Argent. You could not tell the difference until you were about 3 feet away which rim was covered over with Argent and which was just poweder-coated.
By the way for 4 bucks a can I'd buy one can that AhamusJ used and one I used and see which one you like the best
Old March 31st, 2017, 03:47 PM
shamusj's Avatar
No worries- walk on. Im open to hearing all the different approaches.
shamusj is offline
Old March 31st, 2017, 04:10 PM
Paladin31's Avatar
I'm walkin here
thanks Shamus
stevengerard
Wheels and Tires
February 21st, 2017 06:06 PM
Texas442
Paint
45
April 9th, 2015 09:21 PM
onofre442
September 10th, 2013 02:24 AM
LI Olds
Wheels and Tires
April 6th, 2013 08:30 PM
68cuttysupreme
Wheels and Tires
July 26th, 2011 07:12 PM
Quick Reply: SSII Argent Silver rattle can option....Rustoleum Soft iron
