56 Super 88 Conv: Where is the conv top pump?
Old August 27th, 2011, 01:16 PM
The_German's Avatar
Strange story:
Sometimes the switch causes reaction in the conv top hydraulics, sometimes it does not.
There is power on the switch and the switch puts the power on the up, resp down cable, but no reaction.
I need to know how to get to the pump to see if the power arrives there.
Strangely enough, there is no wiring diagram in the shop manual, no clue, why that is the case.
Can you help?
The_German
The_German is offline
Old August 27th, 2011, 03:41 PM
1956 holiday coupe
hialeah56's Avatar
do you have this book? I wonder if it would help, I think these show operation and service
btw there's two to choose from right now on ebay
http://www.ebay.com/itm/1956-Oldsmob...item5642dfa09b
http://www.ebay.com/itm/1956-OLDSMOBILE-CONVERTIBLE-TOP-MANUAL-BROCHURE-ORIG-/170587100639?pt=LH_DefaultDomain_0&hash=item27b7c8 95df
hialeah56 is offline
Old August 27th, 2011, 06:45 PM
youngin'
56oldssuper88's Avatar
maybe a short or a bad switch?
56oldssuper88 is offline
Old August 28th, 2011, 08:12 AM
The_German's Avatar
Hialeah, I have that book, but I need more, I need the wiring diagram for the roof and also the location of the relay switches and the electrical connections at the pump.
From the trunk side I see some tubes etc, but no cables etc.. Where is all that stuff??
Old August 28th, 2011, 08:16 AM
Tedd Thompson's Avatar
Top pump
Behind the back seat, under the boot that holds the top when its down is a aluminum box which holds your motor and pump.This may be reachable from the trunk( I can't remember for shur it's been awhile) once there you can check the motor from that location. Hope that helps... Tedd
Tedd Thompson is offline
Old August 28th, 2011, 08:18 AM
The_German's Avatar
Tedd, there is something like a bottle visible, but no wires. I will rush out to the garage now and see, if I can find it!! Thanks so much!
66olds98conv
Ninety-Eight
March 21st, 2013 12:52 PM
valmaye
February 19th, 2012 10:41 AM
oldspackrat
January 30th, 2012 08:12 PM
LoganT5262
October 17th, 2010 06:59 AM
aholiday
January 11th, 2010 05:57 AM
Quick Reply: 56 Super 88 Conv: Where is the conv top pump?
