324 Engine Build
Old April 10th, 2024, 04:41 PM
madmax442.com
madmax442.com's Avatar
324 Engine Build
So, I am starting a new thread to document my 324 build. I will try to post as many pictures as I can. I am having a shop build the short block. I "could" do it, but I prefer the same folks that do the machine work to build the bottom end. I have been collecting parts for 3 months. I am now only waiting on pistons, rings, bearings, and the camshaft. I obviously had to wait for the initial machine work to be completed so I could order pistons and bearings.
I am doing an upgraded stock build, my '55 is mostly all original. I am sourcing a complete 324 here, as my 324 still runs, in fact driving it tonight to take the wife to a birthday dinner. This block and crank are still '55. The heads I will attempt to build are '56 # 10 heads. The block cleaned up at .060 over and the crankshaft at .010 on rods & mains.
Upgrades:
#10 heads: mild porting and blending, nothing too radical, hardened exhaust valve seats, all new guides and valves. I am going to attempt to reuse springs, but won't know until way later after they get assembled and can check seat pressure.
Camshaft: Camcraft 212 @.050, .495 lift HCR profile https://www.camcraftcams.com/wp-cont...s-4-12mod1.pdf
Timing Set: Ross Racing double roller with advance/retard keys
Pistons: Egge L2133 .060 over https://egge.com/product/egge-piston-set-with-pins-161/
Rear Main Seal: Best Gasket 3772 Rubber seal
Stock Stuff:
Rocker Shafts: stock, reuse everything, already cleaned and ready to go.
Pushrods: Will see if stock pushrods work after decking block and heads
Oil Pump: Have a stock cleaned up one within end play spec, but will put new gears and spring in it
Thank you John for core!
#6 cylinder had the worst pitting of all 8.
Bored .060 over, still needs honed. Im taking to get an extra hot tank tomorrow.
Here's the same #6 cylinder.
madmax442.com is offline
Old April 10th, 2024, 04:53 PM
2blu442's Avatar
I'm glad to see the progress your making on this project!
2blu442 is offline
Old April 10th, 2024, 06:45 PM
Rocket Renegade!
Just wondering if Ross does pistons. Those Egges are famous for their low compression height and resultant reduced CR.
BangScreech4-4-2 is offline
Old April 10th, 2024, 07:14 PM
madmax442.com
Probably, but budget-wise staying conservative. Ill post a pic of them when I get them tomorrow. The compression height is reported to be 1.875.
Old April 11th, 2024, 10:02 AM
madmax442.com
The block has one of these coolant passage plugs (like a freeze plug) on each side, I just removed them both before taking the block to get cooked and hot tanked. They are there to manage coolant flow from the factory. After removing them, there were presumably what I think are factory casting rod pieces down in there. I pulled them out.
File Type: png
Old April 11th, 2024, 10:10 AM
madmax442.com
I just read they are spikes so they don't drop down into the block. They were detached already. https://www.jalopyjournal.com/forum/...plugs.1219337/
Old April 11th, 2024, 01:41 PM
madmax442.com
Ok here are the pistons from Egge. They are indeed 1.875 for compression height. They look pretty nice.
Old April 11th, 2024, 05:18 PM
madmax442.com
These snap rings are way easier than other ones I have seen.
Old April 12th, 2024, 01:30 PM
madmax442.com
I cleaned up the rods, wire wheel, etc. Ready for recon. I ordered the small end bushings may or may not need them. The pins fit snug by hand but don't fall out.
Old April 12th, 2024, 04:45 PM
madmax442.com
Just got the block back from thermal cleaning. Wow!
Old April 12th, 2024, 05:02 PM
Sugar Bear's Avatar
Was the block bored before the pistons were in hand?
Yes the rods in post #4 look like casting supports.
That is a C L E A N block, it looks great.
Sugar Bear is offline
Old April 12th, 2024, 05:10 PM
madmax442.com
No I waited until boring was completed before I bought the pistons. It was left .005 extra, new pistons will get honed in.
Old April 17th, 2024, 06:15 AM
Wally's Avatar
Madmax, with 0.060" over standard pistons I calculate your new displacement as 334 cubic inches.
I'm really interested in how this turns out. I have a couple 324 blocks that I will be building one of these days.
Wally
Wally is offline
Old April 17th, 2024, 07:18 AM
madmax442.com
Wally
Yes me too! Interesting the 2nd Gen Olds 330 was 3.385 stroke & 3.938 bore. This will be 3.4375 stroke & 3.935 bore.
Old April 19th, 2024, 08:42 PM
madmax442.com
Dropped off my pistons, rods, and bearings with my machine shop. He still has to deck the block, recon my rods, then hone in pistons. I'm basically letting him build the short block minus the cam. I told him I'll try not to bug him, but I will! Lol
Old April 22nd, 2024, 04:35 PM
madmax442.com
Got my cam today! Engine still at machine shop for a bit.
Old April 25th, 2024, 08:03 PM
madmax442.com
So still waiting on the machine shop with my block and crankshaft. In the meantime, I found a balancer finally and sent that to Damper Dudes. I also found an oil pan from a salvage yard in Minnesota, $200 bucks but I really need one. I want to build a complete motor as much as possible without have to remove and swap over everything. Once I pull my motor and trans, I want to do a quick swap. I will have my existing 324 that is original to the car as a fairly complete spare. I could always part it out after I get sick of storing it, we will see.
Old April 28th, 2024, 05:43 PM
madmax442.com
Don't put the seal in backwards!
coppercutlass
November 6th, 2022 08:50 AM
oldsmoboogie
November 9th, 2021 05:47 PM
coppercutlass
June 10th, 2021 08:06 AM
oldstata
February 20th, 2014 06:19 AM
coppercutlass
July 8th, 2013 07:56 PM
Quick Reply: 324 Engine Build
