Trying to I.D. my transmission
Old October 30th, 2023, 11:32 PM
Kapos79kutlass's Avatar
Hello olds family , im working with a olds 455 / th350 . About to button it up and slide it into my 79 cutlass . Nothing spectacular just stock overhaul any ways im needing a kickdown cable for it and also just for my own knowledge id like to know more about my trans. Decoding my engine i know its 73 out of a delta 88 . Id like to know more bout the trans .only numbers i came across is on the govenor cap ( LC030N75 ) and an B5 on the top Of the caseing . Do i need to search more or is any of this useful ? Mainly trying to find out year and if it a olds
Kapos79kutlass is offline
Old October 31st, 2023, 04:42 AM
To ID the transmission look at the pan.
If it came from a 73 Delta 88 chances are it's a TH 350 or TH 400.
Olds64 is offline
Old October 31st, 2023, 05:23 AM
Shoveling Snow
Hairy Olds's Avatar
Post a photo of the ID tag that is riveted to the case.
Hairy Olds is offline
Old October 31st, 2023, 02:50 PM
more than likely that is the die used when the case was cast at the foundry.
I work in a Big 3 transmission assembly/aluminum casting plant, every part cast has an identify letter/number cast into it. That make finding suspect parts much easier to find if there is a die issue.
matt69olds is offline
johnnyrockets
May 14th, 2020 05:45 AM
BlackDogJake
August 6th, 2018 11:57 AM
billmerbach
May 20th, 2014 02:37 PM
84oldsDelta88
September 30th, 2011 09:20 PM
84oldsDelta88
January 19th, 2010 11:04 AM
Quick Reply: Trying to I.D. my transmission
