need detent cable for th350 trans
Okay so I have a 1984 delta 88 with a swapped 350 and th350 trans that came out of a 1970 cutlass. The detent cable that came with the trans was the style which mounted to the pedal. i tried the detent cable from my old th200c but the cable wouldnt fit into the hole on the th350. o and i'm using the original quadrajet carb from the 307.
Where can i get a cable for this setup? What cars came with a 350 trans that the cable attached to the carb that i could make use of?
Thanks for the help guys.
84oldsDelta88
January 19th, 2010 11:04 AM
