need detent cable for th350 trans
Old September 30th, 2011, 04:10 PM
84oldsDelta88's Avatar
Okay so I have a 1984 delta 88 with a swapped 350 and th350 trans that came out of a 1970 cutlass. The detent cable that came with the trans was the style which mounted to the pedal. i tried the detent cable from my old th200c but the cable wouldnt fit into the hole on the th350. o and i'm using the original quadrajet carb from the 307.
Where can i get a cable for this setup? What cars came with a 350 trans that the cable attached to the carb that i could make use of?
Thanks for the help guys.
84oldsDelta88 is offline
Old September 30th, 2011, 05:02 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Just go to any parts store, and order one for a 77 cutlass with a th350 instead of an 84 delta.
You just have to fool their stupid computer system.
J-(Chicago) is offline
Old September 30th, 2011, 09:20 PM
You are the man, thank you I'm gonna order it tomorrow
Bitburger
July 14th, 2015 02:28 PM
Bitburger
June 30th, 2015 06:59 AM
Tony72Cutlass'S'
September 8th, 2012 12:05 PM
jerseyjoe
May 5th, 2011 06:49 AM
84oldsDelta88
January 19th, 2010 11:04 AM
Quick Reply: need detent cable for th350 trans
