Torque Converter Recommendation TH 400 and 455
Old October 8th, 2016, 08:00 AM
David DeCan's Avatar
Looking for Torque Converter (Brand, Stall, Approx Cost, Model), recommendations for my 70 Cultass Convertible. Here are the specs:
455---HP/Tq approx 400-450
TH 400 with shift kit
4 core radiator and will put in trans cooler if necessary
3:31 posi gears Chevy 12 bolt
5500 RPM max
Street car. Stop light to stop light kind of car. Top down highway cruiser as well. Will never see the track.
Thanks.
David DeCan is offline
Old October 8th, 2016, 08:25 AM
What cam is in it?
oldcutlass is offline
Old October 8th, 2016, 09:00 AM
To be determined but leaning toward Comp Cam 270/501 and 501. Stock valve train, springs, rockers. Edelbrock Performer 2151.
Old October 8th, 2016, 09:14 AM
It says it will work with a stock cam, but you can go 1 step over stock with an 1800-2000 rpm stall. Give TCI or any of the TC manufacturers a call for a recommendation.
Old October 8th, 2016, 09:26 AM
Senior Moment Member
z11375ss's Avatar
Great advice. Call the manufacturer. They will hook you up with the exact converter that will work best with your car. They know it all.
z11375ss is offline
Old October 23rd, 2016, 12:43 PM
transman74's Avatar
With what you've got so far, I can't see any reason that a stock TH400 converter won't do. Until you've sorted out what the final outcome of the engine/diff ratio/tire size is finished, don't p-ss your money on a high stall and then find out that it's all wrong.
There are a number of high stall converter builders that can/will give you the right converter for YOUR APPLICATION.
You can contact Paul at T.C.S. in Langley, B.C. Smart guy, used to own a performance engine shop and at one time was crew chief on a Pro-Mod car. T.C.S. converters are warrantied and made in Canada so you pay in Canadian funds. You can check out their website www.tcsproducts.com and see what they can offer you.
Do it right-once
transman74 is offline
Old October 23rd, 2016, 06:58 PM
z11375ss's Avatar
Having a slightly slippery converter is pretty damn fun. Like 3500 with a mildly built motor.
z11375ss is offline
Old October 23rd, 2016, 07:04 PM
Chevy budget Olds powered
coppercutlass's Avatar
With 400-450 hp im sure its gonna need some stall highly doubt the stock converter will be ok . My 355 has a 3000 stall and it great around town but it has a pretty stout cam.
coppercutlass is offline
Old October 23rd, 2016, 11:11 PM
Rocket Renegade!
You don't have to use very much cam to get those numbers out of a 455. No need to go to a particularly high stall unless it's just for the sake of entertainment.
BangScreech4-4-2 is online now
Old October 24th, 2016, 05:49 AM
But even a 2200 2500 stall helps. It's not just about the power but driveability. I once ran a w30 cam with a 2000 stall and it did not want to idle in drive. To took alot of tuning just to get it to do that. Went to a 2800 stall and it changed. I'm not saying put a 3000 stall in it but a 2400 stall would be perfect. My 3000 stall does not slip very much around the street. For the best bang for the buck you could get your factory converter cleaned and re stalled. We have a local shop that does that. Stock units usually can go upto 2400.
cus
July 5th, 2016 11:10 PM
GINCSC
December 19th, 2015 01:49 PM
shamusj
May 24th, 2015 06:19 AM
4door!cutlass
March 27th, 2014 03:55 PM
olds455
June 5th, 2010 07:15 AM
Quick Reply: Torque Converter Recommendation TH 400 and 455
