TH350 Gear Whine
Old September 15th, 2016, 09:20 PM
77ricbaez's Avatar
TH350 Gear Whine
My Cutlass has always had a whine in FIRST GEAR ONLY, like if it were a muncie rock crusher. Shifts well, no other noise coming from the transmission.
Just wondering if it is normal for the THs to make the gear whine noise in first.
Also I should add that the pitch corresponds to the RPM, and if i drive it in Low gear and let off the gas the pitch goes down like the muncies do (and there's a bad-a** exhaust popping too)
77ricbaez is offline
Old September 15th, 2016, 09:56 PM
same but different
don71's Avatar
I don't mind a little whine in those gears. I consider that normal, with out other symptoms, I wouldn't worry about it.
Popping in the exhaust, leads to other problems. That could indicate incorrect timing or tune up issues.
don71 is online now
Old September 16th, 2016, 08:08 AM
jpc647's Avatar
IS the bad add exhaust pop when you let off after winding up first gear? Leads me to think the car is pig rich and the unburnt gas is "exploding".
jpc647 is offline
Old September 16th, 2016, 12:05 PM
77ricbaez's Avatar
Yes I drop it in first and wind it up to about 2000 RPMs and let off
Old September 16th, 2016, 12:21 PM
Hookers under Hood
76olds's Avatar
The whine is normal, I use to get it through the original radio. Running it up to 2k shouldn't be an issue at all once you let off. As Don mentioned, its sounds like you need a tune up with timing put into it.
Eric
76olds is offline
Old October 26th, 2016, 03:31 PM
goatwgn's Avatar
Whine is just noise from the planetary gears. Usually first and reverse do it in TH350s. They did it in mine until the gears themselves actually broke after two "freshen up" type rebuilds when it had close to 500000 miles on it. The replacement makes the same noise. Even the TH400 in my old Pontiac makes a little bit of the same whine. I wouldn't worry about it.
goatwgn is offline
Old October 26th, 2016, 04:07 PM
Have some cheese with the whine..., if its not ungodly loud its normal. The popping can be an exhaust leak also.
oldcutlass is offline
Old October 27th, 2016, 06:42 AM
oddball's Avatar
IIRC one major part of the TH350 spins at twice input shaft speed when in first, and that gets noisy. Intermediate drum? I'm trying to think back 15 years here....
I've had 6 or so TH350's, they all did it.
oddball is offline
Seff
November 30th, 2014 07:57 AM
W30Olds
Drivetrain/Differentials
20
December 12th, 2013 03:54 PM
1BOSS83
July 18th, 2013 07:58 AM
86ChebbyWagon307
July 5th, 2011 07:09 PM
woodie582
September 19th, 2008 11:14 AM
Quick Reply: TH350 Gear Whine
