200-4R Pump Stator Washer
Hi all, I have my 200-4R out of my Custom Cruiser right now to take care of a leaky pump seal, and when removing the pump I noticed that the plastic stator washer had a couple chewed up tabs that help it guide onto the pump. Unfortunately I'm not having much luck finding a replacement washer in the same color-coded thickness, but I have found some online that are thinner by about .014 to .020". My question is, if I'm unable to find a replacement washer, should I put the old one back in with the worn-out tabs? Or should I buy the thinner washer at the risk of extra endplay?
Photos of the washer and where it sits for reference:
Thanks!
Thanks!
that one isn't that bad. You can run that one - I've seen worse. You will need some trans gel to hold it into place when you put the pump back on. You can clearance thicker ones by wet sanding them on a granite table to the thickness you need. These have be reproduced in a few sizes - before then you had to do the above. Seems to be that washer moved when the last person torqued into the place. ^ Trans Gel
