Noob here- Need help with VIN for getting title
Hi All,
I'm working on a deal to pick up a '66 Toro... my first restoration job - very excited!
Car has no title, but here's the nameplate under the hood. Can anyone help me decipher where the VIN is? I'm going to pay a service search it for me to see if I can get a title. Also, if you would, let me know if
66 Toro
there's any other useful or neat information within the nameplate. Thank you!
66 Toro
The VIN number is on the driver's side door hinge pillar, the Trim tag is what you have pictured, there is no vin number there.... getting a Title can be difficult, you maybe going down a road with a dead end.
The VIN will be 13 characters and will start 396876Mxxxxxx.
That car was built the fourth week of Jan, 1966 in Lansing, MI. It was originally Champagne Mist upper and lower body color, with a fawn (antique parchment) strato bench interior. It came with tinted glass, power windows, power seat, A/C, rear seat speaker, and deluxe seat belts. I can't find a reference for the 3P code anywhere, however. That one has me stumped.
I follow you completely. Before going to look at the car I read this and found 369021F by the water pump heads 394548 and 394(646) (i think, it's hard to read). Motor is red so I know off the bat its the wrong motor for a Toro.
https://classicoldsmobile.com/forums...cation-112127/
Same here! I've got a '68 455, second or third hand, and was told it came from a Toro. It was in a Ford truck when I bought it. It is red from the factory. Though not a sure fire indicator, the VIN derivative on it is 38M60094(5?). The last digit was not stamped very well. It has a "K" intake manifold. I know this is not Gospel, but the old Oldsmobile FAQ site has this line:K 398664 '68-'69 455 Toro. It also has a Toro short-base aircleaner.
This is a 1968 Toro motor in it's original habitat.
Thanks, Joe; still learning, every day! I'm pretty sure the red is original, though it was on pretty thick on the VIN pad. I scraped off several coats and never found any different colors.
Last edited by BackInTheGame; June 9th, 2021 at 09:16 AM. Reason: added info about color/paint
olds53rocket
December 22nd, 2006 05:46 PM
