Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Distributor Vacuum Control Switch
Old February 19th, 2021, 01:30 PM
ranmat2's Avatar
The vacuum control switch on my 1972 Cutlass Supreme 350 Auto Tranny has a black wire which leads to firewall. At that point the wire is exposed with a raw end. The best I can determine this is supposed to connect somehow to the transmission. Does anyone know if this correct and if so where is the connection point at the transmission?
ranmat2 is offline
Old February 19th, 2021, 02:21 PM
I assume you are talking about the DVCS used in the Transmission Controlled Spark system. The two terminals on the top of the valve operate a solenoid vacuum valve that turns off vacuum to the distributor vacuum advance can unless the trans is in high gear. One wire provides +12v to operate the solenoid. The other runs to the connector on the side of the trans. The plug on the trans should have two wires in it, this black one and a black w/orange stripe wire that controls the kickdown solenoid in the TH400. All 1972 Oldsmobiles got these wires and plug in the harness no matter which transmission was installed
joe_padavano is offline
Old February 19th, 2021, 02:28 PM
ranmat2's Avatar
Thank you so much Joe. I don’t how this wire got broken however your information will enable me to get under the car to repair the connection.
ranmat2 is offline
Oldssupreme
July 14th, 2022 06:43 PM
Kensey
October 9th, 2018 05:42 PM
ddd777
April 10th, 2013 05:55 AM
2Cutup
August 12th, 2011 03:33 PM
ct1979
December 22nd, 2006 10:22 PM
Quick Reply: Distributor Vacuum Control Switch
