Distributor Vacuum control switch
You'll have to get one off someone that has an extra, they dont make repros last time I checked, is your car missing one? You could just connect your distributor to potted vacuum thats what alot of folks have done. All the dvcs does is kick in the manifold vacuum to prevent overheating. But I'm sure there are varied opinions on having one installed.
Cheers,
Tony
Cheers,
Tony
Thanks Tony,
That's the problem I can't find anyone that has it. All aftermarket. My Cutlass is not overheat but the temp is a little high and I'm not sure if it's the duration of the cam or this switch. Only happens at idle.
https://classicoldsmobile.com/forums...dspackrat.html
https://classicoldsmobile.com/forums...s/2blu442.html
https://classicoldsmobile.com/forums...nracing77.html
Good luck with your search. This is what you're looking for:
You'll have to get one off someone that has an extra, they dont make repros last time I checked, is your car missing one? You could just connect your distributor to potted vacuum thats what alot of folks have done. All the dvcs does is kick in the manifold vacuum to prevent overheating. But I'm sure there are varied opinions on having one installed. Cheers, Tony
ddd777
April 10th, 2013 05:55 AM
