conversion
Old August 13th, 2008, 09:37 AM
venividivici53's Avatar
conversion
i have a 54 olds 324 with auto trans , i want to convert to standard , my question is will a 54 buick motor and standard fit in the olds , and will i have trouble putting the pedals in thanks JOE
venividivici53 is offline
Old August 13th, 2008, 10:02 AM
I have no direct experience but my guess would be no! GM didn't start using corporate engines and drive trains until the late 70s.
Olds64 is offline
Old August 13th, 2008, 11:45 AM
thanks olds 64
thanks olds 64 , how about a 53 olds , think i would have a problem with the motor , trans, and pedals , to install into my 54
Old August 14th, 2008, 05:11 AM
Junior Member
88 coupe's Avatar
Originally Posted by venividivici53
........ will a 54 Buick motor and standard fit in the olds ........
If both cars are the "entry level" Olds 88/Super 88 vs Buick Special/Century, they are the same ('54-'56) car, with different drive trains. Olds used the conventional open driveshaft/leaf spring configuration, but Buick used a closed design, called a "torque tube, with coil springs.
Bottom line? Unless your fabrication skills are up to modifying the components, or changing the whole enchilada, it would not be a good idea.
........ will i have trouble putting the pedals in ........
Since they are the same car, the pedals/linkage should be a direct fit.
........ how about a 53 olds ........
Engine and (manual) trans is a direct interchange. Side cover on the '53 Hydro would not clear the '54 floor.
........ and pedals ........
'53 pedals may, or may not, work in a '54.
Norm
88 coupe is offline
Old August 14th, 2008, 01:33 PM
thanks for advice
norm thanks for advice , ill shy away from buick and go for the 53 , JOE
Old August 14th, 2008, 01:34 PM
thanks norm , think ill go with the 53 olds JOE
J'ville
July 10th, 2009 03:18 PM
JoshF85
March 15th, 2005 10:50 AM
grandmas73rocket
December 7th, 2004 10:30 AM
strumagic
December 7th, 2004 10:17 AM
strumagic
March 1st, 2004 10:08 AM
Quick Reply: conversion
