conversion
conversion
i have a 54 olds 324 with auto trans , i want to convert to standard , my question is will a 54 buick motor and standard fit in the olds , and will i have trouble putting the pedals in thanks JOE
Bottom line? Unless your fabrication skills are up to modifying the components, or changing the whole enchilada, it would not be a good idea.
Since they are the same car, the pedals/linkage should be a direct fit.
Engine and (manual) trans is a direct interchange. Side cover on the '53 Hydro would not clear the '54 floor.
'53 pedals may, or may not, work in a '54.
Norm
