Headers
Old June 14th, 2017, 08:50 AM
my71olds's Avatar
Headers
Hello
What are the opinions on headers? I have a 71 cutlass with the 350 and dual exhaust. Do you think headers will help with performance/more HP?
my71olds is offline
my71olds's Avatar
Any suggestions are welcomed!
my71olds is offline
Old June 14th, 2017, 09:27 AM
Long tube headers are an improvement over stock exhaust. Will it register on the butt dyno, probably not.
oldcutlass is online now
Old June 14th, 2017, 09:49 AM
Eric is correct. Your butt dyno will probably not be able to tell the difference. It will change the sound of your car's exhaust note though.
Be prepared to change header gaskets. They can blow out, especially if you buy a set of cheap headers.
Olds64 is offline
Old June 14th, 2017, 10:12 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You are looking at 15-30 hp and torque dependent on short or long tube etc. The Sanderson shorty headers fit nice. What size pipe is your dual exhaust?
olds 307 and 403 is offline
Old June 14th, 2017, 04:17 PM
First, the more air (and thus fuel) you can move in and out of the engine, the more HP it will make. Proper tuned full length headers have been proven time and time and time again to provide about 20-30 HP increase over stock manifolds. More importantly, this improved exhaust breathing is an important foundation for any other performance upgrades you plan to make. I personally wouldn't waste my time with shorty headers.
joe_padavano is offline
Old June 14th, 2017, 04:21 PM
Originally Posted by my71olds
Hello
I much prefer headers over factory manifolds as headers will flow a lot better than the factory exhaust manifolds. I have a set of Heddmans on my car and they have held up well over the past 30+ years. No gasket blow-outs, loose bolts, etc.
Is your '71 350 still in factory form (8:1 compression and puny camshaft)?
Fun71 is offline
Old June 23rd, 2017, 06:25 AM
wcourt3010's Avatar
Go out and get yourself a pair of hookers. Headers that is.
wcourt3010 is offline
Old July 13th, 2017, 09:07 AM
my71olds's Avatar
Yes still in factory form
my71olds is offline
Old July 13th, 2017, 10:11 AM
IMO if all you're planning to do is look at upgrade to an existing dual exhaust? Not worth your time and money. If you're planning to change intake, cam, lifters then I'd consider the headers
It all comes to how deep your pockets are and what your plans are for using the car. Show car? Nope. DD, maybe. Performance, yup.
Allan R is offline
Old July 13th, 2017, 10:14 AM
except that no 71 CS verts came from the factory with deck wings, and those side mirrors appear to be one year only 1970.
Allan R is offline
Old July 13th, 2017, 10:20 AM
my71olds's Avatar
Originally Posted by Allan R
except that no 70 CS verts came from the factory with deck wings, and those side mirrors appear to be one year only 1970.
its a 71 and the spoiler was added not by me
my71olds is offline
Old July 13th, 2017, 10:22 AM
my71olds's Avatar
I was talking about the engine
my71olds is offline
Old July 13th, 2017, 10:31 AM
One other thing you'd have to consider is moving the brake distribution valve if you put headers in. Check the location and you'll see what I mean.
Sorry, I apologize for the other comments. I thought you were talking about the car in general.
Allan R is offline
Old July 13th, 2017, 06:35 PM
If you put in Sanderson shorty headers, nothing need moved, you just need custom down pipes. They are much roomier than in my Gbody.
Old July 13th, 2017, 06:48 PM
my71olds's Avatar
What part # for your Heddmans? Full length right?
my71olds is offline
Old July 13th, 2017, 09:56 PM
Not necessary on small blocks, but may be required on big blocks. The Heddmans fit without relocating the valve on both my 70 and 71 with 350 engines.
Fun71 is offline
Old July 13th, 2017, 09:57 PM
Not sure about the part number, I bought them back in the 80s. 58150 comes to mind, but again, it's a memory from last century.
And yes, full length.
Fun71 is offline
Wyze
March 18th, 2012 01:59 PM
martine
February 13th, 2007 11:57 AM
JoshF85
January 24th, 2006 10:20 AM
javi58
April 20th, 2005 07:53 AM
<72>
November 11th, 2004 09:09 PM
Quick Reply: Headers
