Engine oil
Old November 18th, 2010, 04:41 PM
554drholiday's Avatar
Engine oil
Do you need a special oil for in a 55? I was asked if you did or not?
Thank You!
554drholiday is offline
Old November 18th, 2010, 05:29 PM
citcapp's Avatar
I run Shell Rotella 15/40 weight has the additives you need for your engine. You will get lots of opinions on this one
citcapp is offline
Old November 18th, 2010, 06:46 PM
Coltonis's Avatar
I prefer to oil all my engines with baby seal blood. Sure its a bit "dicey" to obtain, but nothing beats its lubricity properties...
This post wasn't even remotely helpful. I appologize.
Coltonis is offline
Old November 18th, 2010, 09:38 PM
Jaybird's Avatar
Originally Posted by Coltonis
I prefer to oil all my engines with baby seal blood. Sure its a bit "dicey" to obtain, but nothing beats its lubricity properties... .
Hmmm!!! Kind of interesting, in a strange way!!!
Jaybird
Jaybird is offline
Old November 21st, 2010, 08:58 AM
85olds442's Avatar
Oils to use with flat tappet cams.
You will want to use an oil with Zinc, There are some better than others. Summit Racing sells there own brand of oil with 10w30 5w30 10w40 and 15w40 There is also Royal Purple and Amsoil. Those are probably the best ones to use. My Opinion I use the Royal Purple in my 1968 Olds 350 with a Hydralic cam. Works great. Alittle pricey at 7.99 a quart. But cheaper than going to a roller cam set-up. hope this helps.
85olds442 is offline
Old November 21st, 2010, 10:16 AM
You are going straight to hell! Oops, I see you already live near there.
FWIW, I also use Rotella T 15W-40. You can get it really cheap at Sam's Club.
Olds64 is online now
Old November 22nd, 2010, 08:06 AM
Lady72nRob71's Avatar
Here are some good threads about oil. Our older cars need zinc to help protect the non-roller cam parts. Easiest and cheapest solution would be a diesel engine oil.
https://classicoldsmobile.com/forums...23784-oil.html
https://classicoldsmobile.com/forums...18372-oil.html
https://classicoldsmobile.com/forums...motor-oil.html
Lady72nRob71 is offline
Old November 22nd, 2010, 08:34 AM
Registered
Bluevista's Avatar
That seal oil is really good for your seals and gets my seal of approval.
The hides make really good seat covers after the Eskimo women chew on them for a couple of weeks to soften them up.
Bluevista is offline
Old November 22nd, 2010, 08:58 AM
Cutlass Lover
cutlassgal's Avatar
Oh God, Blue!!! You are tooooo funny!!!
cutlassgal is offline
Old November 22nd, 2010, 10:28 AM
Jharken's Avatar
Delo 400 15-40
CJ-4
Jharken is offline
72Blazerod
January 1st, 2015 10:04 AM
805cut
May 3rd, 2012 08:11 PM
86pontiac
February 17th, 2010 11:24 AM
njot33
September 25th, 2009 09:07 AM
Quick Reply: Engine oil
