Home Porting Techniques
Old January 18th, 2015, 08:08 PM
  #841
80 Rocket's Avatar
Went to the flow bench with a C casting. Both Dave (the Freak) and myself had our ports flowed. The premise was simple. Have the best flowing port with just a valve job and bowl work. Dave kept it conservative and I went a little further to see the difference. Heads were flowed at 28" and all heads listed had 2.07" intake valves.
Here is the flow bench results:
80 Rocket port:
.100- 64
.200- 132
.300- 192
.400- 223
.500- 250
.600- 267
The Freak port:
.100- 69
.200- 132
.300- 193
.400- 223
.500- 248
.600- 260
For comparison purposes here is a Joe Mondello race port C which was flowed on the same flow bench a few months ago:
.100- 67
.200- 140
.300- 188
.400- 222
.500- 247
.600- 268
.700- 280
These ports are preliminary testing. We still are working with different valve jobs and we did not backcut the valves. There is another ace up our sleeve, but that will be a teaser to keep you tuned into this thread.
80 Rocket is offline
Old January 18th, 2015, 10:32 PM
  #842
67 Cutlass Freak's Avatar
Wish I could have gone with to see our heads flowed. I had a feeling Don's bowl was going to flow better than mine. We wanted to do them a little different. I was really surprised about the exhaust port flow numbers. Kind of hard to believe just a good bowl blend and valve job could be right there with the Edelbrocks & much better than the Pro Comps. There's a lot of room for improvement. Don did all his port work with an electric grinder, and I used air. Here's some action shots-
This was a lot of fun and interesting results. We did not remove any bumps or work any of the ports other than the bowl area. These tests should be just what the Doctor ordered.
67 Cutlass Freak is offline
Old January 18th, 2015, 10:44 PM
  #843
X-peri-mental Port Work
I spent most of the day working on the junk E casting Jeremy gave me. I decided to raise the roof and floor of one of the exhaust ports. I have a lot of hours into this. I hope it does well on the flow bench. This head is just to see what type of results could be had in a max effort cast iron head. John from Rocket Racing gave me the idea to weld externally above the port, then start grinding. He also suggested the "D" shape. I went a little crazy here-
Old January 18th, 2015, 11:42 PM
  #844
Bernhard's Avatar
Very cool
Thanks for sharing
Bernhard is offline
Old January 18th, 2015, 11:43 PM
  #845
Bernhard's Avatar
Originally Posted by 80 Rocket
Project "X" has commenced
Nice
Bernhard is offline
Old January 19th, 2015, 06:18 AM
  #846
80 Rocket's Avatar
Originally Posted by 67 Cutlass Freak
That reminds me.......I gotta shave.
Old January 19th, 2015, 10:59 AM
  #847
69455's Avatar
More info
Edelbrock heads
Bowl work / tear drop guides
Back cut valves
.100 74.5
.200 148.3
.300 202.4
.400 242.2
.500 259.8
Max CFM 261.5
Avg CFM 206.3
69455 is offline
Old January 19th, 2015, 02:05 PM
  #848
80 Rocket's Avatar
Originally Posted by 69455
Edelbrock heads
Back cut valves
.100 74.5
.200 148.3
.300 202.4
.400 242.2
.500 259.8
Max CFM 261.5
Avg CFM 206.3
Thanks for the info. Were these heads flowed at 28"?
I do want to mention that Dave, nor myself are hung up on flow numbers. We look to have a small block and big block dynoed in the upcoming months to substantiate the flow numbers. And from there.......ET slips........
Old January 19th, 2015, 02:29 PM
  #849
69455's Avatar
correct 28
With out back cut valve job almost identical to super freaks #'s
69455 is offline
Old January 19th, 2015, 02:42 PM
  #850
80 Rocket's Avatar
correct 28
Super Freak? That name is perfect. If we ever meet, remind me to buy you that beer I offered you just now.
Old January 19th, 2015, 04:34 PM
  #851
Out of Line, Everytime😉
olds 307 and 403's Avatar
Nice numbers guys, the X is a nice touch. Are you talking old or new style Edelbrock's, assuming old style.
olds 307 and 403 is offline
Old January 19th, 2015, 06:34 PM
  #852
80 Rocket's Avatar
I am not basing the Edelbrock flow numbers off of their website (new heads) because everything I have heard is they are quite inflated (by about 10cfm). The flow bench we tested on showed that as well.
Old January 19th, 2015, 11:16 PM
  #853
Seasoned beater pilot.
J-(Chicago)'s Avatar
Heez-A-supa freak , soup-a-freak.
J-(Chicago) is offline
Old January 20th, 2015, 06:31 AM
  #854
Is my hair not luxurious? The fire hazard is worth the risk. Playa be gettin' all the bitches.
Old January 20th, 2015, 10:20 AM
  #855
80 Rocket's Avatar
Thanks a lot J.......next time I see Dave he'll probably keep sayin "I'm Rick James, bitch" as he is grinding away.
Old January 20th, 2015, 10:32 AM
  #856
69455's Avatar
All I good fun.
Hope no feelings got hurt Bitch.
Ill collect that beer later
69455 is offline
Old January 30th, 2015, 09:22 AM
  #857
mstrader77's Avatar
I've been watching this thread for a while and thought I might contribute some minor information. Hopefully this won't derail the thread. I recently filled the crossovers and did some port work to my KA heads for my jet boat. Melting the aluminum was one of my big challenges because I don't have a oxy/ace torch. The method I found was to use a brush burner that I bought from Harbor Freight for $16 dollars. I broke up an old aluminum impeller from a Berkeley jet pump. The impeller was broken up into smaller pieces and placed in a stainless steel flour container. The brush burner took about 5-6 minutes to melt the aluminum. The pour went smooth.
mstrader77 is offline
Old January 30th, 2015, 02:56 PM
  #858
Glad it went well for you. I have used old pistons, and intake manifold chunks before. I found the Zinc alloy, sold by guys like Smitty, melts at a slightly lower temp, and has less impurities to skim off. It also seems to pour smoother, more fluid. My best advice to anyone doing this would be to melt a little extra, and over pour. It tends to shrink a bit. Also be careful when grinding the pour out, it's easy to damage the seat.
Do you have any photos to share? The next one I do I'm going to check temps/ melting point.
Old February 1st, 2015, 08:34 PM
  #859
mstrader77's Avatar
Here are a few pictures. This is my first attempt with porting and filling crossovers. In a couple of months I'll test the boat out and see if I improved them or not. I figured the worst case scenario would result in a pair of new aluminum heads.
Old February 8th, 2015, 01:50 PM
  #860
Chevy budget Olds powered
coppercutlass's Avatar
Ok so today I was working on the cylinder heads the freakman ( 67cutlassfreak) poerted for me. I have already got the spring heights all set up ., but when I did that I checked for valve lift clearance and figured out I did not have nearly enough. So I studied the subject and there are a few options like .050 locks and retainers that will give you more valve lift clearance by raising the retainer. That's an option but it will throw your installed spring heights off. In my situation I don't even think I would be able to run that many shims under the spring., so I bit the bullet and ordered the tool that comp cams sells to cut the guide to fit Viton seals . This tool does 2 things it cuts the diameter of the guide for the seal to fit properly and it will also cut the height down.
Here is what I used Nothing fancy . I opted against a drill because the cutting bits are brazed on and from experience with machining sometimes a slower cut yields a much better cut. My main thing for using the speed wrench with a 12 point 10mm socket was to not trash the bit if it happen to dig into the metal which at high speeds would mess things up. This tool cuts pretty good with a speed wrench to be honest and there is less room for error.
Now The area to check for adequate valve lift clearance is between the very bottom point of the retainer and top of the seal . Lunati recommends .090 . I had 565 on this measurement I was checking with the seal I had but once I get the correct seal it will open up more .This is explained later.
Now this is what the cut guide looks like. I made only a .075 cut because I got a .500 cutter I ordered a .530 but got the wrong one. Seals are cheap enough so I just gotta order new Viton seals for the smaller diameter.
Im showing this because many guys wanna do just a bigger cam but it really is not that simple. With a Viton seal I had just a bit over .500 clearance., the heads where previously cut for Viton seals. Checking for clearance is not that hard and the tool is only about 85 bucks. You get to do 2 things though. You get to make sure you have enough clearance and you get to upgrade to a much better stem seal.
Now My question for the olds pro's is how much can you cut down the guide? Obviously im not trying to cut it down to nothing but everywhere I look I cant seem to find this info. What is the same margin for bringing the guide down ?
I had to re type this 3 TIMES lol. First post was much more detailed and after doing it 3 times I had to condense it a little for my sanity.
coppercutlass is offline
Old February 9th, 2015, 12:54 PM
  #861
80 Rocket's Avatar
What is your installed height? Those are stock guides, correct? You should be fine taking .150 off the top of the guide.
Old February 9th, 2015, 03:15 PM
  #862
Installed spring height is 1.700 . Valves dave set that all up I got the paper work for it but gotta dig it out.
Old February 12th, 2015, 08:33 PM
  #863
80 Rocket's Avatar
In an effort to make this the most comprehensive resource on Oldsmobile cast iron cylinder heads on the interwebs........I got some more info for everyone to digest.
I checked the intake runner port size as measured in cc's.
#3 head- 1.875 valve, stock 151cc
#4 head- 2.07 valve, bowl work/guide work 163cc
G head- 2.00 valve, stock 163cc
E head- 2.00 valve, stock 165cc
C head- 2.00 valve, stock 171cc
Ga head- 2.07 valve, .160 raised roof, bowl/guide work 178cc (these heads are on my 80 Cutlass with a 355 small block)
Also, in the big block head variety, it seems the C castings and all prior heads have a taller roof inside the port by about .150" compared to the E and G head varieties.
Old February 12th, 2015, 09:25 PM
  #864
80 Rocket's Avatar
That would look good on a cylinder head. When it has this "X" it means that you mean business and that Fords and Chevies should probably yield to you.
Old February 13th, 2015, 12:58 PM
  #865
BlackGold's Avatar
Perhaps a lower spring pocket to make room for the valve rotators which were introduced in 1970?
BlackGold is offline
Old February 13th, 2015, 02:05 PM
  #866
80 Rocket's Avatar
I suppose that's a possibility. But there is water in between the spring pockets and port roof. And I do not think the castings changed in regards to where the spring pockets were cast. The only change would be how far down they machined them. They go .200" further in the deep pockets. And you certainly do not want to venture any further past that lest you hit water.
But I am not 100%. Gotta cut some more heads in half. Who's got bad castings that are cracked/damaged that they want to donate to the cause?
Old March 18th, 2015, 10:26 PM
  #867
Still Porting
I can't hardly believe how many views this thread has gotten since I started it. I'm glad there's a bunch of do-it-yourself-ers still out there. Porting heads is not really hard work, just very time consuming. Over the past year and a half I have learned a lot, and developed my own techniques. I have been aproached by a few people, and am on my third set of small block heads, over the past two months. I really do enjoy this stuff. I know I'm goofey in the head.
Over this past winter I have improved the lighting, insulation, and organization of my garage. Including my porting station. Check it out-
I installed a six bulb flourescent fixture directly above my work station with a magnetic tool holder mounted to it. I also picked up a diamond stone shaper from Harbor Freight for less than $10. This thing works slick. I've had trouble finding stones shaped just right. Now I can make my own modifications-
I have gotten a little faster by using the right bits and stones for each task at hand. I have come to the conclusion that doing home porting without some seat grinding equipment, would be extremely difficult. You would be basically guessing where the lowest angle of the valve job ends. If you plan on doing more than one set of heads you should pick up a used valve seat grinder, a stone dresser, and some various sizes of stones. If your planning on doing only one set, I suggest you talk to your machine shop and see if they would be willing to rough in the valve job. That way you can do your port work, not worry too much about nicking the seats, and take it back for the finish clean up valve job.
Here's some unported intake bowls, & two that I just finished tonight-
I still believe there is a demand for quality cast iron port work. I have been working with my good friend Don (80 Rocket), to develop a strategy to supply a quality product, with the best parts and machining, at an affordable price. We have some ambitous plans, but we need to do a bit more research, before we introduce our offerings to the Olds community.
I suggest that every body that has an pinion, on what they want or need for cast iron heads, goes here, and expresses their opinion-
https://classicoldsmobile.com/forums...ad-thread.html
Old March 19th, 2015, 06:56 AM
  #868
wr1970's Avatar
Keep up the good work guys. I am really enjoying the effort and you showing results and the pictures.
wr1970 is offline
Old March 19th, 2015, 07:41 AM
  #869
miksan
miksan's Avatar
X-2
miksan is offline
Old March 20th, 2015, 06:55 AM
  #870
74sprint's Avatar
X-3
74sprint is offline
Old March 22nd, 2015, 09:46 AM
  #871
Milan..'s Avatar
Dave , your work area and ports , look very nice......
Milan.. is offline
Old March 22nd, 2015, 10:39 AM
  #872
Ready Set Port!
Recently someone commented that it should take 3-4 hours to port a head. There is no way in hell I can do it that fast. Maybe I'm just too slow or meticulous. I thought it would be fun to do a little actual time posting from beginning to end of one intake port. So if anyone wants to race me... get your safety glasses, paper face mask (screw that), and stock your fridge. Oh crap there's only 3 in there. At least it's good beer.
These heads belong to a friend of mine named Bob, my friend Nick introduced him to me. He has an '80 Trans Am with a 403. We started out with some good #5 cores. They were cleaned, checked for cracks, milled .050" and had new bronze guides installed. They are shooting for a good performing street combination with maybe an occasional blast down the strip. You can go here to read about it-
http://realoldspower.prophpbb.com/topic7297.html
So my first step will be to remove a bit of material in the bowl area with a 1/2" round nose carbide. Here's the before shot of the bowl-
Time to crank some tunes and get my daily iron intake.
12:40 PM CST Let the fun begin...
Old March 22nd, 2015, 11:19 AM
  #873
captjim's Avatar
If you are referring to a post i made in Don's "iron head" thread, I meant 3-4 hours for a little bowl clean-up, not a serious port job. You know way better than I do since you do them, but i imagine you could easily have 40-50 hours in a pair of max heads.
captjim is offline
Old March 22nd, 2015, 11:25 AM
  #874
As you can see I've started to bring the bowl back on the long side radius and done a little work on the walls. The parting lines are starting to dissapear. I will stop to check my work periodically. The bowl will end up being pulled back aproximately .150" further, later on in the process.
Next I will switch over to a long 3/8" egg shaped carbide. I will use this to work the short side radius by tapering and widening. Also for tear dropping the guide and working the side walls a bit more.
1:25 CST
Old March 22nd, 2015, 11:32 AM
  #875
Hookers under Hood
76olds's Avatar
A set could be done in 3-4 hours if you had a 5 axis high speed CNC machine along with a good holding fixture. You could knock alot of set-up time down after the first off is complete. I would say a set could be done in under an hr, if you were tooled up .
You would need exco-carb ball nose cutters with a min of 12,000 rpm spindle in order to keep cycle times down with tool changes. That would be roughing out with a 3/8 ball and finishing with a 1/4 ball possibly 3/16 ball if tighter rads need to be achieved.
76olds is offline
Old March 22nd, 2015, 11:58 AM
  #876
It's hard to get a good shot of the short side radius, but I just try to smooth the transition into the bowl, and square off (widen) the sides-
With the guide, I just remove the cast iron right up to the bronze insert. You shouldn't do this on an aluminum head.
I try to widen the troughs on each side of the guide, and transition them into the bowl. The parting lines are gone now on the sides. Remember, this is not an all out port job-
Now I'm going to flip the head and do a little port runner work with the same long egg carbide. I will get rid of the bump from the rocker stud boss, work the roof and sides a bit. I will just scratch the floor. I don't want to remove any material there. These heads will not get the raised roof treatment. The owner does not want to match port the intake, so it makes no sense to take any extra off the roof. Soon I will head back to the bowl.
1:59 CST
Old March 22nd, 2015, 01:09 PM
  #877
So I've gotten rid of the bump on the roof, smoothed the runner near the guide, widened the sides slightly, and just cleaned the casting from the floor. Most of the work in the runner is done just past the entry, near the push rod pinch point. The roof also needs a little work to straighten out the entry. Where the side walls do their turn I will straighten it some. Before grinding shots -
After a little grinding-
Now I will do a little smoothing with a 3 1/2" X 1/2" tapered stone and then a cartridge roll -
3:10 CST
Old March 22nd, 2015, 01:36 PM
  #878
That didn't take very long at all -
Next it's time to break out the heavy artilary and start to rough in the valve job. I need to clean the guide first. I use a soft bristle brush on a drill for this.
3:37 CST
Old March 22nd, 2015, 01:56 PM
  #879
I have already ground a 45 deree angle into the new stainless steel valves. We are using over sized 2.07" intake, 1.71" exhaust.
These are the various stones I will be using to perform the valve job -
Start out by dressing the 45 degree stone -
Find the best pilot that will fit snug into the guide . I have them in .001" increments. This one is .342" -
Set up the dividers to the outer part of the seet contact area. On the intake it will be at the top 2.07" -
Now this is going to take a little while to open up the seat this far.
3:57 CST
Old March 22nd, 2015, 02:39 PM
  #880
When I get out to the 2.07" mark, I will go slightly past that.
Next I will mark the seat on the 45 with a sharpee -
Next I will bring the 30 degree stone in just enough to break the top edge. I don't want to sink the valve. I did not want to pollish the combustion chamber here, because we are trying to increase the compression ratio on this lack luster 403.
Next I set up my needle tip dividers to .060" this will help me to establish the valve to seat contact area.
4:41 CST
Quick Reply: Home Porting Techniques
