63 cutlass transmission mount
Old May 24th, 2022, 05:51 AM
05fathead's Avatar
looking for an automatic transmission motor mount, fits 61-63
05fathead is offline
Old May 24th, 2022, 06:05 AM
I deleted your double thread. Have you check Fatsco Transmissions?
https://www.fatsco.net/
Olds64 is offline
Old May 24th, 2022, 06:11 AM
05fathead's Avatar
yes
Old May 24th, 2022, 07:16 AM
You should let us know what car and transmission you need the mount for.
Olds64 is offline
Old May 24th, 2022, 07:35 AM
05fathead's Avatar
post is titled 63 cutlass and there is only 1 automatic transmission, roto hydramatic 5
Old May 24th, 2022, 08:05 AM
The mount is P/N 1361633, and it is the same on all 1961-63 F85 and Special/Skylark with any trans. No one sells new ones, only the revulcanization service, so either you need a good used one or search for an N.O.S. one on ebay. Eric Jensen might have a usable one.
joe_padavano is online now
Old May 24th, 2022, 08:23 AM
05fathead's Avatar
thanks joe, already tried him. he thought someone modified their crossmember to make an early 70's mount to work .
Old May 24th, 2022, 08:32 AM
If the newer mount is the same height, drilling holes in the crossmember is pretty easy.
Old May 26th, 2022, 12:49 PM
05fathead's Avatar
joe, do you have any used mounts for dimensions????
Old May 26th, 2022, 01:03 PM
I have one in the shop. Let me dig it out.
Old May 26th, 2022, 09:18 PM
edzolz's Avatar
Is this the same as the GM one bolt type or the two bolt, like a Muncie four speed?
edzolz is offline
Old May 27th, 2022, 05:56 AM
05fathead's Avatar
2 bolt
Old May 27th, 2022, 05:58 AM
Nothing on the Y-body cars is the same as on any other GM.
Old May 27th, 2022, 06:14 AM
05fathead's Avatar
hey joe, if you could get me center to center bolt holes and height , i might be able to get something to work. thanks ( you should see what this pair of hands did to this car, i should have taken picture )
Old May 28th, 2022, 02:41 PM
The two threaded holes for the bolts to the crossmember are 1.25" apart. The two holes that bolt to the trans tailhousing are 3.75" apart. The mount is 1.75" tall.
Old May 28th, 2022, 03:05 PM
05fathead's Avatar
awesome, thanks joe!!! so i can use an anchor 2378 if i slot holes in crossmember and possibly mount also. it's 1.8" tall 1.5" at crossmember and not sure at trans 3.75-4". thanks for your help!!!!
carwashwiz
July 16th, 2015 07:03 PM
tailfins
November 15th, 2013 06:19 PM
Atdog
May 21st, 2010 07:57 AM
tailfins
October 25th, 2009 09:11 PM
Quick Reply: 63 cutlass transmission mount
