hubcap tool
Old January 25th, 2010, 05:49 PM
R.I.P S.K.P
onecutlass's Avatar
hubcap tool
does anyone have the tool to help me unlock these hubcap off my 83?
if you have a pic of it i can wait and get it fron good ole gm tia !
heres the granny spoke wheel
onecutlass is offline
Old January 26th, 2010, 02:45 AM
Yellowstatue's Avatar
Smile Trapped
That little rocket just pops off and then what you need is a tubular key with the correct CODE letter...stamped on the end of the lock bolt is a letter A, B, C, etc. and then when you have the letter off the bolt go to the wreckers and see if they have yours in stock...they usually do not throw those things away... the dealer price might be a little high
Yellowstatue is offline
Old January 26th, 2010, 04:59 AM
It might be a little high if you are Bill Gates or Warren Buffet. If you are a normal guy then you probably can't afford the dealer price.
Olds64 is online now
Old January 26th, 2010, 05:59 AM
Lady72nRob71's Avatar
Post the letter here when you get it.
My mom stupidly got rid of her 86 Olds after failing emissions and it had a MINT set of these hub caps. It went to the boneyard somewhere but she kept the hub cap key. I will try to remember to ask her if she still has it and find out the letter.
Lady72nRob71 is offline
Old January 26th, 2010, 06:06 AM
Registered
Bluevista's Avatar
One word will get those wheel covers off...BFH.
Bluevista is offline
Old January 26th, 2010, 06:17 AM
csstrux's Avatar
Usually a good tire shop will have tools to get them off as well. They will be universal and might mar the bolt up...but they will be off.
csstrux is offline
Old January 26th, 2010, 08:49 AM
R.I.P S.K.P
onecutlass's Avatar
hey there fellas if i can find the tool is there another way to get the lock off on another olds board i was told i can get them off with needle nose pliers iam plan on keepin the hubcaps if i plan on selling the car ! thanks in advance !
Old January 26th, 2010, 08:59 AM
R.I.P S.K.P
onecutlass's Avatar
i cant see any letter any bolt on all four corners ! how does the tool work does it push or pull the halfmoons ?
Old January 26th, 2010, 09:37 AM
marcar1993's Avatar
It has half moons that catch the half moons on the bolt to turn it, like a normal socket would on a normal bolt.
Yes, you can use needle nose pliers, that is what I did. Then I just used a normal bolt (1/4-20 I think) with a washer under the head so now I can remove them with a socket and a ratchet.
marcar1993 is offline
Old January 27th, 2010, 02:31 PM
R.I.P S.K.P
onecutlass's Avatar
i got them off took two screwdrivers to get them off ! thanks too all that chimed in !
thank so much fellas !
deaddds
May 13th, 2010 06:04 AM
vettemad
January 20th, 2010 10:23 PM
27T
December 10th, 2008 12:44 AM
Rabbit
February 12th, 2007 10:53 PM
Quick Reply: hubcap tool
