Installing a Griffin Radiator in a 67' 4442
Old September 29th, 2011, 07:54 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
Just wondering if anyone ever installed a Griffin radiator in a 67 442 before. I had a 2 core before which couldn't keep my 455 below 200 degrees. The lower brackets for the 2 core might not be wide enough. I did get brackets along with the radiator, will play with them first. I just don't want the car to be down for a long time so if anyone has done this before I'd appreciate any help or tips. Thanks.
67Olds442X2 is offline
Old November 18th, 2011, 04:44 AM
Navy P-3 FE (Ret.)
After removing stock brackets and mounting the new brackets, radiator mounted up nicely. Even the stock shroud fit.
Old November 18th, 2011, 08:47 AM
ddx77's Avatar
Not to change the subject but what are you using for a fan.
Glad you got that one to fit okay. I just put an aluminum radiator in my 67 as well, but not a Griffon.
ddx77 is offline
Old November 18th, 2011, 11:33 AM
Navy P-3 FE (Ret.)
I'm using the stock 4 bladed fan. Works great.
Old November 18th, 2011, 11:54 AM
Pretty easy huh!!!!! How much was that puppy??
oldcutlass is online now
Old November 18th, 2011, 03:11 PM
Navy P-3 FE (Ret.)
Fairly easy. $373 at Summit. The new braided lines cost almost half as much.
Old November 18th, 2011, 04:19 PM
ddx77's Avatar
Great looking engine bay! Love the dual quads too!
ddx77 is offline
Old November 18th, 2011, 05:32 PM
chrisneu68olds's Avatar
Where did you get the valve covers?
chrisneu68olds is offline
Old November 18th, 2011, 07:48 PM
Navy P-3 FE (Ret.)
Got the covers through Summit. Pricey but nice and solid.
http://www.summitracing.com/parts/NAL-22525295/
Old November 18th, 2011, 07:52 PM
Navy P-3 FE (Ret.)
Thanks. I've added a few things since then.
Alex72cutty
April 21st, 2015 10:30 AM
59Olds98
August 14th, 2013 09:38 AM
kitfoxdave
May 27th, 2013 01:28 AM
g77rvd
May 13th, 2011 11:29 AM
n9ljx
Alero
August 14th, 2006 06:24 PM
Quick Reply: Installing a Griffin Radiator in a 67' 4442
