Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Sticking Valves
Old November 21st, 2015, 05:36 PM
truckerlary's Avatar
Sticking Valves
I have a 327 sbc that seems to have some sticking valves from setting for over a year. Is there some method of unsticking the valves without removing the heads. I was told that if you put a quart of transmission fluid in with the engine oil and let it run it might unstick them. This engine is in a 64 Impala ss that I'm redoing. Any help will be appreciated. Larry
truckerlary is offline
Old November 21st, 2015, 06:46 PM
wr1970's Avatar
Marvel mystery oil upper cylinder lube!!
wr1970 is offline
Old November 21st, 2015, 07:26 PM
MMO, rislone, transmission fluid all will help. If your gas is old it turns to varnish and causes the problem.
oldcutlass is online now
Old November 21st, 2015, 09:33 PM
same but different
don71's Avatar
If I were in the same circumstance, I'd use Marvel MO too or seafoam, I like it too. They both have their place in the market of symptoms like this.
don71 is offline
Old November 21st, 2015, 09:36 PM
Sugar Bear's Avatar
Larry,
What is the symptom? Is it a ticking noise from a sticky valve lifter or is it a misfire/low compression from a valve sticking?
Sugar Bear is online now
Old November 21st, 2015, 10:05 PM
Ozzie's Avatar
Larry,
I agree; let's do an accurate diagnosis before applying the solution.
Ozzie is offline
Old November 22nd, 2015, 11:54 AM
It is missing on a couple cylinders, haven't figure which ones for sure. Also seems to have a little tappet noise on the right side. Also firing thru the carb when accelerating. Probably going to pull the valve cover and see what is happening. Not sure anything will free them up but worth a try. Thanks for all the info. Larry
Old November 22nd, 2015, 03:38 PM
I'm wondering if you may have wiped out your cam.
Old November 22nd, 2015, 05:19 PM
I'll just have to pull the valve covers and see. This car was driven from Illinois before it was parked and seller said it was fine.
Old November 23rd, 2015, 05:40 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have had great luck with straight atf for freeing stuck rings. I would try that and something like Kleenflo Combustion chamber cleaner down the carb. A flat cam on a Chevy, that never happens.
olds 307 and 403 is offline
Old November 23rd, 2015, 06:35 AM
Sugar Bear's Avatar
Larry,
64 Impala SS nice car...
Things to check:
1. Distributor cap for carbon tracking,
2. Broken rocker arm,
3. Bent pushrod,
4. Collapsed valve spring,
6. Collapsed lifter,
5. Camshaft lobe(s) worn flat.
Good luck and please post the solution.
Old November 23rd, 2015, 02:23 PM
Looks like the lobes on the cam for the number 1 and 2 cylinder exhaust valves are wore down. The rockers are barely moving on these 2 valves. Tried tightening them but to no avail. Anybody got a mild cam for a 327 chevy( I'm serious). Thanks all for the help.
Old November 23rd, 2015, 02:45 PM
A new cam and lifters is not that expensive. Sorry yours is worn, that's usually the issue when your popping out the carb.
Old November 23rd, 2015, 09:20 PM
Sugar Bear's Avatar
It is almost certain the cam is the problem; but, you may want to check for bent pushrods and/or broken rocker arms first since they have to come off anyway. If it is a rocker arm, it is usually the exhaust rockers that fail. They tear open at the bottom, inspect them for wear if you replace the camshaft.
Good luck!!!
Old November 24th, 2015, 05:48 AM
Good luck!!!
I'm fairly sure it is the cam. Watching the rockers while it is running these two aren't moving very much on the push rod end. If it were a cracked rocker that end would be moving about the same as the others. Just my thoughts.
Old November 24th, 2015, 06:11 AM
You'll know for sure once you pull the intake and lifters.
DanOldsMan
August 20th, 2017 03:38 PM
Kanesdaddy
July 8th, 2014 11:04 AM
yamahondarider
Brakes/Hydraulic Systems
October 11th, 2013 03:59 PM
Tedd Thompson
February 19th, 2011 09:39 PM
Olds Dad
December 9th, 2010 05:31 AM
Quick Reply: Sticking Valves
