55 Sticking Stop Lights
Old December 6th, 2010, 10:05 AM
Collector of Stray 55's
Olds Dad's Avatar
Picked up a 55 S-88 4Dr sedan over the weekend - a cheesy backyard resto but it runs strong and is very driveable and looks good from 20 feet away at 20 mph...I noticed that the stop lites stay on after the brake pedal is released and I have to pull the pedal up (only about a quarter inch) and they go out - any thoughts short of a new brake unit (new one in the car according to the seller).
thanks
Olds Dad is offline
Old December 6th, 2010, 10:26 AM
InfoJunkie
InfoJunkie's Avatar
I had the same problem with a dailu driver I bought last year. After about a week the lights started shutting off on their own and it's been fine ever since. If it's been sitting for a bit, the switches get "gummed up" and a bit of use gets them "ungummed".
InfoJunkie is offline
Old December 6th, 2010, 06:56 PM
Rickman48's Avatar
A squirt of WD-40 and moving it in and out wil usually correct it.
If you look, they can be adjusted, if necessary.
Rickman48 is offline
Old December 8th, 2010, 11:48 PM
oldsmobum's Avatar
If you have the stock setup, you will see what kind of looks like a bolt coming out of the brake arm near the top. That is the contact screw for the switch. In order for the brake lights to go out, that screw must make contact with that switch. Screw it out until the it makes contact with switch when the brake is fully released. Press and release the brake pedal a few times to check and make sure its working okay.
oldsmobum is offline
Old December 9th, 2010, 05:31 AM
Olds Dad's Avatar
Yes...stock set up - I did adjust it (Four turns beyond the point at which they just go 'off' according to the shop manual). I think the problem here is the pedal itself is returning at a very sluggish rate - I took some other advice from this thread and squirted some WD down the plunger rod - they seem to be better now - hopefully after a few long rides all will be well!...
Olds Dad is offline
DanOldsMan
August 20th, 2017 03:38 PM
The Bug Man
Brakes/Hydraulic Systems
October 18th, 2014 07:04 AM
Kanesdaddy
July 8th, 2014 11:04 AM
yamahondarider
October 11th, 2013 03:59 PM
Tedd Thompson
February 19th, 2011 09:39 PM
Quick Reply: 55 Sticking Stop Lights
