Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Adding power windows
Old November 13th, 2012, 03:12 PM
Hey everyone. I have an 02 Silverado with crank windows and I want to get a set of doors with power windows and locks. How hard is it going to be to retrofit the truck with the windows and locks, or is it any big deal?
I would imagine it would be about the same job as on a car but with two less windows to worry about.
The power window doors also have speakers built into them, but that's for another time.
Thanks for any advice.
slantflat is offline
Old November 19th, 2012, 11:19 PM
Aceshigh's Avatar
As long as the circuits are ran for the power window motors, should be simple.
If the wires aren't ran, then it will be a bit more complicated.
Aceshigh is offline
Old November 20th, 2012, 08:27 AM
Hm you know I never considered that the truck would be wired for the windows already, probably ease of manufacturing. If the truck isn't to be built with power windows, the harness remains empty. I vote for that one.
Old November 20th, 2012, 12:00 PM
garys 68's Avatar
I replaced a damaged door on a GM car years ago. The damaged one had power windows, the used one I picked up at the salvage yard did not. No harness in the used one, but all the mounting points were there to transfer over the power mechanism. I dont recall if the glass or other parts were intechangable. It did require 3 HUGE rivets that I had to borrow a rivet tool for, to secure the power mechanism in the door.
garys 68 is offline
socalrs
August 14th, 2012 11:07 AM
squirell
April 13th, 2011 05:22 PM
perro
September 4th, 2007 11:52 PM
rustycarr
March 7th, 2007 06:24 AM
Geoffrey Hacker
August 1st, 2004 01:05 PM
Quick Reply: Adding power windows
