First forum ever for HeavyOlds
Old January 22nd, 2017, 07:46 AM
HeavyOlds's Avatar
This is the first forum I've ever joined. Some of you may have seen my head porting videos on YouTube. I've been playing with Oldsmobiles for 38 years. This looks like a great place to exchange information.
HeavyOlds is offline
Old January 22nd, 2017, 08:02 AM
Olds Fever
CRUZN 66's Avatar
Welcome to the site... With 38 years of Oldsmobiling you probably have a lot of info to share yourself and most likely will fit right in with the group... What vehicles have you had or still have???
CRUZN 66 is offline
Old January 22nd, 2017, 08:03 AM
Chevy budget Olds powered
coppercutlass's Avatar
welcome to the site.
coppercutlass is offline
Old January 22nd, 2017, 08:10 AM
HeavyOlds's Avatar
Thanks for the warm welcome
I've had a 1966 Cutlass since I was 13. Originally had the 330. Put in a 425. Broke the 10-Bolt. Broke a 12-Bolt. Broke the steel crank. Put in a 455 with home ported Edelbrock heads. Never did run right until I pulled the heads and found that two valves were out of round from factory. Best of 12.2 on street tires and no 1st gear. The TH400 has finally given up.
Old January 22nd, 2017, 08:15 AM
Nice. My 72 runs 12.4's with a small block iron headed olds on pump gas. Nice looking 66.
Old January 22nd, 2017, 08:33 AM
HeavyOlds's Avatar
Thanks for the compliment. 12.4 is a decent small block time. I put slicks on and obliterated the front U-Joint. It thrashed around inside the loop and also destroyed the long tail shaft housing. I wrecked the rear bushing and possibly bent the tail shaft. Vibrates now. I have a short tail TH400 to put in and EZ EFI to install. I'm thinking of getting a 1350 Chromoly driveshaft from Summit. $250 seems like a good price. Made by Strange Engineering I believe.
Old January 22nd, 2017, 08:34 AM
Welcome to the site, sweet 66.
oldcutlass is online now
Old January 22nd, 2017, 08:48 AM
HeavyOlds's Avatar
Thanks. Nice looking 67.
Old January 22nd, 2017, 08:59 AM
Old School Olds
tru-blue 442's Avatar
Welcome from another member with a 66. Dig the burnout pic.
tru-blue 442 is online now
Old January 22nd, 2017, 09:11 AM
HeavyOlds's Avatar
Thanks. That interior looks a lot like mine minus the A/C. I bet you get some nice cruising weather in Texas. Mine it put away until April or May.
Old January 22nd, 2017, 09:16 AM
Mike77's Avatar
Welcome. Nice to have another BC guy on the site.
Mike77 is offline
Old January 22nd, 2017, 09:26 AM
HeavyOlds's Avatar
Vancouver is our favourite place to visit. We usually stay in Richmond when we're down there.
Old January 22nd, 2017, 09:51 AM
Mike77's Avatar
Don't drive your Olds in Richmond. The worse driver's in the world live there!
Mike77 is offline
Old January 22nd, 2017, 01:16 PM
OldsMoStyle
Mostizzle's Avatar
Welcome aboard.
Mostizzle is offline
Old January 22nd, 2017, 01:22 PM
classicmuscle442's Avatar
Welcome to a best Olds site, love your "66. Sounds like you drove her hard, my '65 was beat on too, twisted both axle's in the pig. Question on no first gear in trans, was that better for racing?
classicmuscle442 is offline
Old January 22nd, 2017, 01:51 PM
HeavyOlds's Avatar
At some point it stopped going into first gear and it hooked up better than ever on those TA Drag Radials and I got a record low 12.2. Acted like a power-glide. After I put the slicks on, broke the tail shaft housing and put it back together, it goes into first gear now. Must have rattled something loose. I will replace my tranny and driveshaft before I attempt the slicks again.
Old January 22nd, 2017, 02:19 PM
Oddly enough i lost 2nd gear in my th350 and most thought it was the common sprag failure. Turns out it was a pump sealing ring. Which explains why it was intermitent . If it hit a dead spot no 2nd gear if the ring turned and sealed voila 2nd gear came back. I currently have a th400 im building for future use.
Also the reason the pump ring broke was i had too much space between the drive shaft yoke end and the tail housing end. There was too much movement imo and all the trans guys i have talked to agree.
Sounds like an almost similar issue.
Old January 22nd, 2017, 05:25 PM
" Hoo yah "
815Cutlass1972's Avatar
Welcome to the site man! I dig that 66 especially that color. I thought of doing a custom color like that to mine, but somehow I keep aquiring projects.
815Cutlass1972 is offline
Old January 22nd, 2017, 09:36 PM
HeavyOlds's Avatar
Thanks, hey did you put that cowl on the 66 or did you find a fibreglass hood with a cowl?
Old January 22nd, 2017, 09:41 PM
HeavyOlds's Avatar
Amazing how a small thing like that can cause a big problem. When I built my 425 I used the stamped steel bathtub gasket with an aluminum intake. Lots of silicone around the water ports. The manifold gradually warped and the silicone gave way all at once one day, hydrolocked #1 cylinder and broke my steel crank in half.
Old January 23rd, 2017, 06:10 AM
Welcome to the site. Very cool car!
Olds64 is online now
Old January 23rd, 2017, 12:28 PM
btw
Smokin' BBQ Member
btw's Avatar
Awesome ride - welcome to CO!
btw is offline
Old January 23rd, 2017, 04:55 PM
" Hoo yah "
The hood was already on the car when I purchased it. It's 66 hood with a cowl that was fiberglassed on the metal hood.
Old October 17th, 2020, 10:32 PM
HeavyOlds's Avatar
A friend at work made a video of my car as a birthday present.
Old October 18th, 2020, 07:43 AM
65B01Delta's Avatar
Sweet video... That is one Romping, Stomping 66..... Well done. oh, I dig the moon roof......
65B01Delta is offline
Old October 18th, 2020, 11:41 AM
Oldsdruid
rocketraider's Avatar
Beautiful launch! No wrath and roll, just a nice little squat and got down to binness!
That starter looks like he's under 25 yo. What did he think of your romper stomper? Since he probably doesn't see much Olds school out there... if it weren't for Mustangs I swear the strips around here would have to shut down.
rocketraider is online now
Old October 19th, 2020, 04:22 AM
35tac's Avatar
Very nice 66 Cutlass. Enjoyed the video. Love those 66's.
Wayne
35tac is offline
Old October 20th, 2020, 06:27 AM
HeavyOlds's Avatar
‘’Lots of Mustangs and Camaros but we get a mix of everything.
Old October 20th, 2020, 07:23 PM
Oldsdruid
I was looking at ET vs trap speed and thinking WTF, then I remembered you're in Canada and trap speeds are in KM. Still some hella quick cars.
That 65 GTO is nasty. The 66 Chevelle is borderline violent.
Thanks! 👍🤘🤙
Old October 20th, 2020, 10:10 PM
HeavyOlds's Avatar
Thanks! 👍🤘🤙
That is still in MPH.
Old October 21st, 2020, 04:46 AM
  #31
Oldsdruid
Yeah. HELLA FAST CARS!
Diluth
April 8th, 2019 02:36 PM
savage'74
March 27th, 2019 03:26 PM
barron1941
December 14th, 2016 08:56 AM
425power
July 15th, 2011 06:23 AM
79TASFLA
July 13th, 2009 04:07 AM
Quick Reply: First forum ever for HeavyOlds
