Glove box lock??
Old September 20th, 2014, 09:51 AM
Mrcutlasss1994's Avatar
Glove box lock??
1969 Cutlass convertible. I think the spring in the glovebox lock has broken. Need to get it open to change out the heater core. Has anyone else had this happen what do I do??
Mrcutlasss1994 is offline
Old September 22nd, 2014, 03:59 PM
Randy C.
rcorrigan5's Avatar
I had the glove box lock fail on my '68 4-4-2 convertible. The way I got to it was to reach around under the dash to the back side. The actual box itself has an opening up by the latch. I was able to use a small screwdriver to depress the latch and open the glove box.
The reason my lock failed was because of the cast iron assembly on the backside of the glove box door that holds the lock cylinder. There is a spring-loaded cast iron lever inside of that piece and it broke. Fortunately, I had a spare backside assembly and I simply replaced the old, broken backside assembly with my spare.
Good luck with opening your glove box door. It takes a little patience and possibly a long arm!
Randy C.
rcorrigan5 is offline
Old September 22nd, 2014, 05:18 PM
Octania's Avatar
Don't forget to lube stuff like that while you have it apart. Makes things work a lot smoother.
Octania is offline
Old September 22nd, 2014, 07:35 PM
2 '66 98's
bigoldscruiser's Avatar
I don't know if they are the same, but on the full size cars all you have to do is unscrew the bezel around the lock and it drops inside the box and the door falls open.
bigoldscruiser is offline
Old September 24th, 2014, 07:54 AM
I got it opened!!
I messed for hours with it, noticed the bexel screw was loose enough to un screw did that and it opened. The spring lever is broken, looking for a new latch, the tmbler is still in good shape. Thanks for all the help.
goldie442
August 21st, 2015 11:01 AM
AZ442
June 11th, 2015 06:26 AM
Kidcutty
June 13th, 2010 07:12 AM
Col Wickham
May 24th, 2010 11:10 PM
justagirlfromla
March 11th, 2010 10:15 PM
Quick Reply: Glove box lock??
