Advice on glue needed- vinyl to hard plastic
Quick question on what glue to use for:
1994 Cutlass Supreme convertible, rear seat back in between the 2 bucket seats. This is the car I'm selling, I just found the vinyl piece that needs to go back on that plastic "trap door" piece on the seat back. This is the hinged piece right behind the console, which when opened you can peer into the convertible's trunk and/or the top motor.
I'm loathe to use spray adhesive but I will if nothing else works,
Any help would be appreciated. I need to get this piece back on securely, as it's really the only ugly thing about this otherwise really nice interior.
Sure is, and for a piece that never should have been there in the first place. Even if the top motor went bad, it won't fit through that hole very easily if at all without making a total mess. Should have just been all dyed as a one piece.
Most coctact adhesive will come loose from the heat (3M super 77, etc). The lanau roof glue is better, 3M trim adhesive and 3M 1357 will hold great. PVC cement works on most vinyl/plastics too.
Got my can of Weldwood, will advise on how this all turns out. I wonder how this stuff would work on adhering the hood insulation to the hood, there's one nagging spot where the clips to not hold it and there is about a 6 inch area on the front part which sags.
70Post
March 16th, 2011 07:21 PM
