1964 Fuel Pump
Chevy pump drives from a pushrod. Olds uses a lever that contacts the cam eccentric.
You should be able to find a rebuild kit for that pump ez enough. That or make a blank-off plate and run a low-pressure electric pump. If you rebuild, get a kit compatible with crap ethanol gasoline.
64 and 63 are the same pump and you can get the rebuild kit for it that updates it for the new gas. I picked up a kit off e bay and it worked out fine. Fusick also carries these pumps if I remember correctly, they should have one at Carlisle this week
Steve
Steve
Nor Cal Andy
March 29th, 2012 07:27 PM
